GeForce GT 710 2GB GDDR3 Or GDDR5??
Solved by Dimitrispaok88,
7 minutes ago, Electronics Wizardy said:Id just get a used gpu if you can, the 710 is a pretty bad value.
Otherwise id get the cheapest model, it really wont matter performance wise.
Thank you. i will see for another gpu. Thanks again.
Featured Topics
eric_s ·
Posted in Power Supplies4 -
1
Silencix ·
Posted in Cases and Mods1 -
4
LambdaBird ·
Posted in General Discussion5 -
2
12
4
2
