Medical Syringes For Liquid Metal Removal?
Solved by porina,
I use generic 1ml syringes fitted with a fine plastic tip to manipulate liquid metal. Haven't tried metal tips. I find it good for producing a small drop of LM where I want it.
Can't give a general source for the plastic tips. I got mine as part of Salifert water testing kits. It is similar size point to that provided by the Conductonaut kit.
Image of the syringe I use at end of thread below:
