OHAI!
I am working out a design for a dual-gpu, dual-system, unraid- & threadripper-based workstation for an office environment. I don't have experience with a lot of the components involved, so I am concerned about thermals, noise (office), and power drain.
The base components I have specced out are as follows:
Software-wise I will be using unraid to run Ubuntu and Win10 side by side, each with a dedicated GPU and a subset of cores & memory - keeping in mind local connectivity of memory interfaces and cores. The load on both systems are a mix of graphics and intense parallelized tasks.
I have no plans for overclocking, relying entirely on PB2, XFR2, and PBO, but am still worried that in max load scenarios of CPU and both GPUs, power drain and heat generation might not be sufficiently addressed. Is that just paranoia or are there additional measures I ought to consider? Is this thing going to be office-uncomfortably loud and what could I do to address that? Parts not registered here include a raid-0 pair of SATA drives for heavier storage.
Basically the goal is for the rig to just sit silently and unassumingly next to my desk.
https://linustechtips.com/topic/1063200-threadripper-dual-system-unraid-workstation/
Thermals should be okay. Your PSU can handle the power draw.
It can be a bit loud as you have two very beefy GPUs and a beefy CPU, however it will DEFINITELY not be as loud as i.e. a computer from the very late 90s
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
Do take note, that RAID 0 increases risk for data loss if you happen to lose a drive.
Also, Unraid doesn't support RAID levels directly, you can't choose it. If you aren't going to run an actual array, then Unraid might not be the best choice. It is just using KVM for virtualization, which you can achieve on pretty much any Linux distro.
Finally, you might need one more GPU to just run the OS, unless you are willing to do some hacks.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Oh for sure - very important reminder. Thanks :)
For this build, that is not too much of a worry as we have a decent offline-cycled NAS on our 1gbit LAN which all workstations do frequent automated backups to. Larger internal storage in any of our workstations is only used for working with heavy base data sets - restored onto workstations when necessary.
My choice of unraid was based on support and seamlessness of hardware dedication/forwarding. We do not have the bandwidth to run much maintenance ourselves.
Choosing only a GPU per VM was based on my impression that unraid is able to run headless, with a web interface for any necessary management. Am I missing or misunderstanding something there?
Assuming I don't actually have noise or thermal issues to address, the case I had in mind is the DeepCool Matrexx55. To me it seems sufficiently roomy and ventilated.
Less useful front panel IO, but with the IO out the back of this motherboard and the intention to have the cabinet on the floor rather than hanging under the rising desk, the plan is to extend the rear IO up to display- and desk-mounted hubs.
Not sure if I am overlooking something critical though. I literally have not built a machine from scratch in this century.
On cooling those graphics cards:
We have a massive 200mm noctua fan sitting around in the office and I was thinking it might be nice to have that as a side panel air intake - right next to the graphics cards.
It would be matched with exhaust fans at the top and back of the cabinet, probably with additional front intakes - with a goal of running all fans at minimum RPM and optimally never have the graphics card integrated fans spin up very much.
Is that a pipe dream / overkill or do you think it would make sense? Also my impression is that side panel fans basically means you're doing your own cutting of some regular side panel plate - or are there specific cases for this?
