Too vague to judge, many parts missing
Desktop benching:
Just now, ForCheddaAboutIt said:
What else is needed?
case, ram, power supply..?
What's your budget and location?
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
A pcpartpicker.com list. Attach a permalink so we can see and make edited versions of your list
Primary PC:
PSU tier list
How many watts do I need?
Don't pay for Windows.. Buy a key on Ebay.. I would get the 2600X w/2080 over the 9600K w/2060.. Made a few other adjustments as well..
Yeah, I know it may not sound like the most smart thing but I have always been a fan of intel and they have treated me well I was hoping to stick with them. Although it seems that you see the gpu to be more important than the cpu is that right?
Don't use an RGB SSD. Its been found they cause serious performance degradation due to overheating.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Do this instead.
The 9400F will perform about the same as a 9600K in most gaming loads (both of which beat all the Ryzen chips), I kept the RGB bling you were going for but while using some slightly cheaper parts. The overall savings allowed for an RTX 2080 while being lower in price! Also the RMx is better than the G3 for cheaper!
Not reallly.. But I rather save $100 and get the 2600X to get a better GPU.. You're not really losing anything, and anything you do, you more than make up for with a better GPU...
And I would not get the 9400F over the 2600X.. but that's just me..
Why not? It's more optimized for his load (gaming). See here:
If you look around on professional review sites as well it even beats out the 2700x OCed. You can see that on Tom's and AnandTech.
2 minutes ago, ForCheddaAboutIt said:
I was looking at that and I don't belive you can overclock the 9400f if im not wrong. Which was something I was hoping to do but other than that it looked good
Yeah that is correct, you can't OC it, but it will outperform OCed Ryzen chips in gaming loads. See the videos above. You'll want to look at the 3400 results on the second video since I've paired my build with 3000MHz (which performs very similar to 3400 due to diminishing returns on Intel with RAM speeds).
He also said he wants to get a 1440p monitor.. Soo... It doesn't really matter, honestly..
