NZXT x62 cpu fan error
Go to solution Solved by suchamoneypit,
Its because its looking for a CPU fan, and you don't have one. You have a AIO liquid cooler with a pump instead. You should be able to ignore this warning in the settings in your BIOS so it doesn't interfere with the booting process, just ensure your CPU pump is in fact powered properly and working.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/1062791-nzxt-x62-cpu-fan-error/#findComment-12556572
