Do you mean that if you try to attach it to the top, the VRM heatsinks and/or RAM get in the way? If so, either return it and get an air cooler, or have a front rad.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1062560-build-help/#findComment-12554412
If you don't have the clearance there's really no miracle to be made but use a different cooler, you can just fill that area with fans and use a high end air cooler to achieve good cold and silent operation.
It's important measure stuff even if it's a hassle to avoid these issues
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1062560-build-help/#findComment-12554425
Yeah the ram and heat sinks were getting in the way, but I found a workaround by placing the fans in the very top of the case and the radiator inside the case (has a little compartment In the top for airflow im guessing)
Which has also increased the appeal of the computer as the radiator is black and the fans are a bit of a grey colour so it just makes the inside so beautifully dark with the tempered glass side panel. The temps seem ok as well so far, cpu has not hit 60 C in a stress test and the gpu hasn't hit 50 (tho did move the fan curve before testing it as the volume isn't that bad to begin with)
https://linustechtips.com/topic/1062560-build-help/#findComment-12554850
3 hours ago, WickedStarfish said:
*snip*
Do your dishes mate! That’s Grimm
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1062560-build-help/#findComment-12555190
