So ive had my PC for about 4 months and up until the past week its been great. Since then, its rare i can get through a full game of r6 without my GPU (RX580 8GB) reaching 100% and the game crashing. I dont know how to fix this, I've updated the drivers to the latest ones and I dont think i have a virus as i have norton which prevents them existing in the first place as well as regularly scanning and removing them. The only thing i can see left to do is reinstall teh game and i really dont want to do that since it takes 6hrs. Any suggestions? The image is a graph of the gpu usage. Note that the GPU and CPU temps are low and the ram being used is about 4gb out of 8.1071441555_Screenshot(7).thumb.png.cb5ec3e01130b4ad86d6f05f2e9fa997.png
https://linustechtips.com/topic/1061551-help/
try using other drivers older drivers may be more stable I recommend searching for the best drivers online
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
https://linustechtips.com/topic/1061551-help/#findComment-12544404
-image-
GPU usage sitting at 100% is supposed to happen. CPU usage should not hit 100%, but that I doubt that is what causes in game crashes even if you do hit 100% on both.
Try rolling back to an older version of drivers. AMD's website has older driver versions available.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1061551-help/#findComment-12544421
Ive tried that and everything else is normal
CPU stress is usually like 50% and all temps are low
the only thing abnormal is the GPU
https://linustechtips.com/topic/1061551-help/#findComment-12544578
Have you used DDU in safe mode in any moment of messing with the drivers?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1061551-help/#findComment-12544618
