On 5/3/2019 at 5:55 PM, andyme said:
i would like to know which i should choose i have narrowed it down to the Phanteks P600s or the bequiet 801 both tempered glass if any other suggestions must support noctua nh15d over 165mm
P600S is overall the better case, as you can adjust how much airflow oyu need by removing the front cover revealing a mesh/fabric intake for better airflow when you need it, and then replace the cover for better silence. The 801 is only good for being super duper quiet and doesnt have much flexibility otherwise.
Alternatives to the P600S are the Fractal Design Define R6/S2, you can review my comparison blog in my signature, but overall the P600S would be my choice.
https://linustechtips.com/topic/1060656-best-case/#findComment-12543951
