SPDIF out vs other connectors
53 minutes ago, Gifton Sundar said:[...] optical one is something else which is used to connect older TVs.
Not really, it's still a current connector used in/on all sorts of places and devices.
In the motherboard pic:
- SPDIF is the optical output, as you know.
- RS-Out and CS-Out would be for rear left + right "surround", and centre + sub most likely, to make up a 5.1 setup. If so, these are TRS analog line-level outputs.
- L-Out is your Line out, and would be green on other motherboards. This is your normal line level TRS analog stereo output if you were running a stereo setup, or front channel left and right if you are doing surround.
- L-In would be your Line in for recording line level sources, and Mic would be for recording mic-level (quieter) sources (it is passed through an internal preamp). Both of these would be TRS analog stereo inputs.
In the second pic (I assume this is what you're sending the sound to?), from left to right:
- DC power jack
- SPDIF optical - this could receive an input from the optical connection on your motherboard.
- SPDIF RCA - I've never used this personally but it's a digital connection over a traditional RCA cable afaik
- The two to the right (white and red) are left and right RCA line in respectively. These could connect to the L-Out port on your motherboard with the right adapter for analog stereo.
- 3.5 mm jack - this can go right to the L-Out on your motherboard for analog stereo.
53 minutes ago, Gifton Sundar said:and, Is it best to use the Optical SPDIF OUT or the other connectors?
You may as well use it since digital is nice and all that but if you have issues, try the 3.5 mm jack
53 minutes ago, Gifton Sundar said:As I don't have enough space or money to mount a 5.1 setup for those connectors(if they are meant for that), I thought of going for a soundbar / 2.1 setup.
So, Is a 2.1 setup better or a soundbar?
soundbars are not great, I'd get proper speakers given the option, it will sound better, assuming you don't get poor ones.
