8 minutes ago, Tevildo said:
Anyone know a vertical gpu mount that would fit in a phanteks p350x?? If theres none can anyone please reccomend cases to me.
https://eu.coolermaster.com/en/case/case-accessories/vertical-graphics-card-holder-kit/
It was designed only for Cooler Master cases but works on pretty much any case with at least 7 PCIe expansion slots in my experience. Much cheaper than the other alternatives I've seen(Lian Li and Cablemod) and works perfectly fine. Using one right now with no issues
https://linustechtips.com/topic/1060178-vertical-gpu-mount/#findComment-12531899
thx
https://linustechtips.com/topic/1060178-vertical-gpu-mount/#findComment-12531905
I've also used that one and it works great.. Puts the GPU pretty close to the motherboard but I guess that's better than being suffocated by the glass like some cases do..
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1060178-vertical-gpu-mount/#findComment-12531933
