Help - 1U Server Noise
Go to solution Solved by Wh0_Am_1,
2 minutes ago, []DarkStar said:
Thanks, Wh0_Am_1,
I acknowledge your reply, I have seen those fans that are talking about just was wondering if there was any other way. I'll ask my mate to check the BIOS for fan profiles, since I'm getting a Internet Speed Upgrade soon so his hosting at his premises since you know Australia, 10/1 Speeds. I like your options C)
I just need some alternative, would I be able to manage the fan RPM's in Ubuntu for example since I know your able to control these settings in windows, and desktops just dunno about servers. Just bought this big plomp of compute power.
Cheers Mitch
Your welcome! Theoretically you should be able to control the fan curve with third party software, it just depends on what the MOBO manufacturer decided to do with their BIOS, as in essence, a computer is a computer, and it runs all the same basic software as a desktop, I even use a few old desktops as home servers.
Hey LinusTT Community,
Me and my mates just recently purchases a second hand 1U Server; Just the norm specs.
CPU: i5-4400
RAM: 4GB DDR3
Storage: 2TB WD Purple
Anyway, my issue is noise. Watch the video below that explains it for you. Is there anyway that I would be able to lower the volume of these fans, I know 1U servers are generally loud for the most part. Like at my school they have blade servers etc, and there isn't as much noise as this one server combined quite funny right. Anyway we are on a tight budget seeing as we bought I low-to-mid level spec'd machine. If your able to help out every post is greatly appricitaed.
-Thanks Mitch, []DarkStar#3147
https://linustechtips.com/topic/1060145-help-1u-server-noise/
Welcome to the LTT forums! I would love to help you, but all I can recommend is A) check your BIOS and see if you can change the fan profile,  B) buy these fans, or and or C) throw it in the farthest corner of your home, and when you need to use it wear good closed back headphones.....
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
https://linustechtips.com/topic/1060145-help-1u-server-noise/#findComment-12531646
Thanks, Wh0_Am_1,
Cheers Mitch
https://linustechtips.com/topic/1060145-help-1u-server-noise/#findComment-12531655
Thanks, Wh0_Am_1,
Cheers Mitch
https://linustechtips.com/topic/1060145-help-1u-server-noise/#findComment-12531668
11 minutes ago, []DarkStar said:
Thanks, Wh0_Am_1,
Cheers Mitch
what model of server is this? You can often make the fans run at a lower voltage to make it quieter.
https://linustechtips.com/topic/1060145-help-1u-server-noise/#findComment-12531676
Not sure on that one mate, I'll have to ask my friend. The bios is like an actual Intel BIOS so I think its a specific from Intel themselves, not to sure I'll ask my friend but his a ruby training he will be back later and i'll get back to ya.
Cheers
https://linustechtips.com/topic/1060145-help-1u-server-noise/#findComment-12531726
