2 minutes ago, rislix said:
is it wrong that i paired the ryzen 5 2400g with gtx 1050 ti?
I don't see much of a problem? Ryzen 5 1600 Probs has better processing power but not a big deal more...
Case: Lian-Li PC-011 Dynamic  CPUi7-7700k (4.8ghz) CPU Cooler: Corsair H100i V2 Case Fans: 5x ML120 RGB / 2x LL120  GPU: Aorus RTX 2080 Xtreme Motherboard: ASUS ROG STRIX Z270H RAM: 32GB Corsair Vengeance RGB Pro DDR4 (3200mhz) Storage: 2x 1TB SG Barracuda, 128gb BiWin M.2 SSD PSU: Corsair RM650x OS: Windows 10
https://linustechtips.com/topic/1060078-help/#findComment-12530893
Just bad money management, a Ryzen 5 1600 + RX 570 would have cost you the same and perform significantly better.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1060078-help/#findComment-12530913
rx 570 cost more power consumption than 1050 ti thats why i dont buy those gpu...
maybe ill sell my ryzen 5 2400g and then buy that ryzen 5 1600
https://linustechtips.com/topic/1060078-help/#findComment-12531005
really sir?
here's my specs of my pc
ryzen 5 2400g
msi b450 gaming plus
patriot steel viper 8gb 3000mhz
seasonic  620watts..
do i have to replace my processor to ryzen 5 1600?
https://linustechtips.com/topic/1060078-help/#findComment-12531035
yes because it has better gaming performance.
11 minutes ago, rislix said:
seasonic  620watts
could you be more specific?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1060078-help/#findComment-12531057
3 minutes ago, rislix said:
that kind of gpu that kills you paying electric bill
It does nothing near that. This is the stuff Nvidia fanboys tell you to keep away from AMD, simply not true.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1060078-help/#findComment-12531091
5 minutes ago, rislix said:
seasonic s12 620 watrs 80 bronze power supply
ill gonna stick to my gtx 1050 ti 4gb oc and not for that kind of gpu that kills you paying electric bill
your psu will flame your house down earlier than a amd gpu of the same performance your electric bill
no, that's not a joke
https://linustechtips.com/topic/1060078-help/#findComment-12531094
1 minute ago, rislix said:
ohh why?
whats wrong with that psu?
Missing protection
Loud as heck under normal/medium loads
Yes, it is
The 1050ti is a waste of money, RX570 is almost 50% faster, cost the same and also comes with up to 8GiB VRAM
If you care about Power Consumption, you stick with the 2400G and use the integrated chip.
The Power Consumption of the 570 is higher but so is 3D Performance as well.
Could we stop that nonsense propaganda/FUD?!
And why ask if you don't care what we have to say...
If you care about Electric Bills, you wouldn't have gotten a Bronze unit, you'd gotten either a Gold or Platinum one.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1060078-help/#findComment-12531141
but its true sir,all 8pins gpu cost more power consumption...
it really has a best performance i admit it but i consider the time frame of playing rpg games that spent more than 5  or 8 hours grinding at minimal power consumption...
https://linustechtips.com/topic/1060078-help/#findComment-12531164
If you really wanted to you could just limit the power limit yourself, but still you have the 1050 ti now so that is what it is. Later down the line, when you upgrade, you shouldn't concern yourself too much with power draw.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1060078-help/#findComment-12531170
5 minutes ago, Stefan Payne said:
Missing protection
Yes, it is
well it cost alot sir...
maybe in your country its fair enough to your thoughts but consider other places sir
https://linustechtips.com/topic/1060078-help/#findComment-12531177
i will keep it on my mind sir..
thanks alot again...
https://linustechtips.com/topic/1060078-help/#findComment-12531191
Then you should have mentioned where you're from.
We assume you're in Europe or the US.
https://linustechtips.com/topic/1060078-help/#findComment-12531225
well what is your budget in your given region?
because there are but a few places where the rx 570 isnt a wildly better buy.
https://linustechtips.com/topic/1060078-help/#findComment-12531628
asia part sir...
rx 570 is a good and high performance...
but the thing is its power grinder..
so i switch to a budget deal with the gtx 1050ti 4gb oc....
and maybe i will sell my ryzen 5 2400g and get the 1600
https://linustechtips.com/topic/1060078-help/#findComment-12532868
asia part sir...
which asia part. because there are a lot of parts in asia where its still a better buy.
your ROI time would be in years. and you will get lower performance. one can allways underclock and undervolt the rx 570. even stock its not very powerhungry
https://linustechtips.com/topic/1060078-help/#findComment-12532909
