Hi,
I'm on tight budget to replace my GPU but I'm not sure whether my GPU or other hardwares are the problem. Can anybody please help me?
THE PROBLEM
When I start my pc, the LED light on my screen turn on, but no display, just black screen. But I can still hear the sound of windows starting.
Then I tried to turn the power off, discharge any power in the system, then turn on the pc again, but this time its on but with very low resolution (800 x 600), and when I check device manager, it says (code 43) on my GPU, when I uninstall and reinstall the driver, after the pc restart, its on with original 1080p resolution for a minute, then the black screen come back.
MY SYSTEM
CPU - i5 3330
GPU - GTX 1050ti
OS - Windows 7
https://linustechtips.com/topic/1059780-my-gpu-broken-or-other-problems/
What version of the GTX 1050ti do you have? What power supply do you have?
Some 1050TIs require a 6-pin power connector while others don't.
You could try wiping all the drivers using DDU, but I'd wait on that because it can cause other issues.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
