re scale for obs settings question?
Go to solution Solved by jj9987,
For Twitch and YouTube, the client-side (meaning the viewer) can choose a resolution below what you are streaming. So if you stream at 1080p or 900p, in both cases viewers can also opt for 360p, 480p, 720p and maybe other resolutions as well, depending on their situation, they are not forced to watch it at the resolution you stream at.
Scaling down on your side adds some additional load on your side too.
so i think i should re scale my output sources from the default 1920x1080 to something like 900p or 1600x900 because it would make for a more enjoyable experience for people stopping into my stream as i dont have any viewers and the majority of viewers i think stopping by would have a potatoe pc no offence should i use the rescale output option found int the output tab as well as output scaled resolution on the video tab set to 1600x900 or just match that to the default 1920x1080 Screenshot_8.png.d99ed8de1f1e4fd1e1cde9618525c498.pngScreenshot_9.png.63aa02c6cbf7a42f19a9e2290163ce8e.png
https://linustechtips.com/topic/1059049-re-scale-for-obs-settings-question/
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
but i thought you had to be partnered to have that on your stream as of twitch which im streaming on
To be able to always get it, yes. If there isn't too much stress on servers, they trickle it down to common streamers. But its random afaik how its delivered. More tiers you have on Twitch, more likely you get it.
But its not that much about resolution than bitrate. Twitch has set bitrate range for each resolution and scaling is more about lowering bitrate when resolution is lowered. If you don't have scaling from Twitch, user only gets "source" option. Meaning that they need to match download speed to get your uploaded bitrate. So 720p is usually under 3500kbps, meaning that 5mb down connection will get smooth experience.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
