Best cooling for a Core 2 Quad CPU Q9550
Turtle Rig
Like the title says what is the quietest fan that will work with a Core 2 Quad CPU.  The key is quiet but handle a overclock.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
hyper212?
23 minutes ago, LukeSavenije said:
or a 212 black (rgb/normal), 33 esports, 34 esports, or many more
but that isn't needed here
meh, the 212 is ok, the 33 & 34 esports don't have LGA775 IIRC.
the Q9550 can get kinda hot.
oh wait... you're actually right, my bad
it can? would a gamaxx300 be enough at stock then?
yeah, but for OC (they could oc quite well), something bigger might be better
He is going to try to overclock for the first time.  I have my old hyper 212 I just realized lol so I will give him that.  But question will it fit on his 775 socket ?
Yes, but it's even more of a pain than usual to install on 775. If you want period authenticity, serious badass points and the most painful cooler installation process ever, check this bad boy out:
https://www.newegg.com/Product/Product.aspx?Item=9SIABW97E36952&ignorebbr=1&source=region&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-Zalman+Direct-_-CPU+Cooling-_-9SIABW97E36952&gclid=Cj0KCQjwkoDmBRCcARIsAG3xzl_zlkzSIPm49YVh4q34SiuKMVj3y3IC5KXJm8E6Hz91y2TdWMOd3NsaAkU8EALw_wcB&gclsrc=aw.ds
Aerocool DS are the best fans you've never tried.
Oh lawhd no.  I still have my thermalright true 120, and it's painful enough.  Don't need to go to the only cooler with worse 775 mounting than it lol
Want to custom loop?  Ask me more if you are curious
It's not that it's particularly bad to mount on 775. It's that it's particularly bad to mount on anything. The mounts on the backplate don't reach the bolts on the cooler, so you have to push down without toppling the thing or sliding it off your socket, then you have to tighten it with this weird ball wrench stick that's more of a screw stripper than an actual tightening mechanism. Oh, and all this time you're slicing your knuckles to ribbons on the razor sharp cooling fins. But damn, is it sexy when it's mounted (that's what she said), and it does a really nice job of keeping things comfortable on moderate to heavy overclocks.
On 4/24/2019 at 5:36 PM, Firewrath9 said:
I agree with @LukeSavenije, however something more performance oriented would be this
I don't. A 212 is fine.
When I was younger I had an Optiplex 755 with a Q9550, overclocked it to 3.4Ghz via PLL, on stock voltage with the standard fin stack cooler. Never went above 65c, even during h.264 encoding. A 212 would probably be overkill with that chip.
My buddy has the same exact CPU (like, my personal chip) in a system I build for him with a newer Intel DX48BT2 board and he's at 3.8GHz at 1.35v. He's got that weird looking Zalman CNPS9900a.
Related image
Sorry about my spelling sometimes. My $1200 laptop has a $2 keyboard.
2 hours ago, BleachedFur said:
I had a Q8400 @ 3.4ghz and some zigmatech cooler that i forgot the name of.
I remember the cooler being decent, but kinda noisy. Some people may not mind, others demand silence. The Gammax 400 is comparable to the 212, but the one I linked would be even quieter, for people who need a bit more performance, at a given noise level.
I have a Q8400 sitting in an EVGA 680i SLI motherboard with no RAM. Once I get some nice DDR2 I'm gonna slap an AIO on it and overclock the snot out of it and see if I can beat an i5 2500.
thats nice!
mine is retired, It still works though.
41 minutes ago, Firewrath9 said:
thats nice!
Although they are old as balls, the Core 2 series of CPU are still good.
Hey Turtle, buy this. You'll be impressed. Here's the build I made for my buddy with the Q9550
https://www.amazon.com/Zalman-CNPS9900A-LED-Ultra-Cooler/dp/B000C0V5RU/
Case? Noctua is good pick for less noise.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
