CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (£137.50 @ Aria PC)
Motherboard: Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard  (£130.35 @ CCL Computers)
Memory: Team - T-FORCE NIGHT HAWK Legend RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  (£129.59 @ Overclockers.co.uk)
Storage: Kingston - A400 240 GB 2.5" Solid State Drive  (£27.00 @ PC World Business)
Video Card: Gigabyte - Radeon RX VEGA 64 8 GB Video Card  (£388.48 @ Ebuyer)
Case: Thermaltake - Versa H22 ATX Mid Tower Case  (£38.48 @ Amazon UK)
Power Supply: SeaSonic - G 550 W 80+ Gold Certified Semi-Modular ATX Power Supply  (£66.82 @ Amazon UK)
Total: £918.22
CPU: Intel Core i5-8600K [Delidded | Frequency: 5.1GHz | vCore: 1.45v - Fuck Intel | Cache: 4800MHz | VCCIO: 1.175 | SA: 1.20]
GPU: MSI GTX 1080 Ti ARMOR 11G OC [Core: 2113MHz | Memory: + 1000MHz | Voltage: 1.181v | XOC BIOS]
RAM: TEAM GROUP DARK PRO EDITION [Capacity: 16GB - 8GB x 2 | Frequency: 3866MHz | Timings: 16-16-16-36]
Motherboard: ASUS PRIME Z370-A
PSU: SeaSonic PRIME Ultra 1000W
Case: Fractal S2 Meshify
CPU Block: EK Velocity | GPU Block: EK-FC1080 GTX Ti TF6 Radiators: x2 HWLabs SR2 360MM  Pump / Res: EK-XRES 140 Revo D5 PWM Fans: x6 Noctua NF-F12
Primary Monitor: Acer Predator XB271HUbmiprz [Refresh Rate: 165Hz | Resolution: 2560 x 1440]
Secondary Monitor: ASUS VG248QE [Refresh Rate: 144Hz | Resolution: 1920 x 1080]
UPS: APC Smart-UPS RT 2000VA [Online | Double-Conversion]
Benchmarks: 3DMark TimeSpy - First [1 out of 8571]
This should do for 1080p easy and even 1440p, you have extra money there for a 2600 if you can find on sale. The price can be cheaper but I personally only shop with Amazon and Ebuyer so that's up to you.
Here's a vega 56 version of the same build but with a beefier psu, going with either the 2060 or vega 56 you'll be happy both can do 1080 and 1440p AAA titles at 60hz
Here's what I came up with for you -
PCPartPicker part list: https://uk.pcpartpicker.com/list/gQgCTB
Price breakdown by merchant: https://uk.pcpartpicker.com/list/gQgCTB/by_merchant/
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  (£67.97 @ CCL Computers)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (£89.99 @ Aria PC)
Storage: Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive  (£108.59 @ Overclockers.co.uk)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  (£36.78 @ Aria PC)
Video Card: PowerColor - Radeon RX VEGA 56 8 GB Red Dragon Video Card  (£313.47 @ Ebuyer)
Case: Thermaltake - Core V21 MicroATX Mini Tower Case  (£55.47 @ Amazon UK)
Power Supply: Cooler Master - MasterWatt 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£54.97 @ Laptops Direct)
Case Fan: Noctua - NF-F12 PWM 54.97 CFM 120mm Fan  (£17.21 @ Amazon UK)
Total: £881.95
Generated by PCPartPicker 2019-04-24 13:06 BST+0100
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
-Snip-
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
30 minutes ago, Alwaroo said:
 this is the build i put my self which im not 100% about can you tell me if its good ?
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  (£79.97 @ Laptops Direct)
Memory: Crucial - Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3000 Memory  (£79.22 @ CCL Computers)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive  (£59.99 @ Amazon UK)
Video Card: Sapphire - Radeon RX VEGA 64 8 GB NITRO+ Video Card  (£410.75 @ Overclockers.co.uk)
Case: Thermaltake - Versa H21 ATX Mid Tower Case  (£36.34 @ Amazon UK)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply  (£68.04 @ Amazon UK)
Total: £908.59
Generated by PCPartPicker 2019-04-24 13:38 BST+0100
Vega 64 is better than the RTX2060. Also got you a proper quality PSU, SSD & additional HDD for storage.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
35 minutes ago, Alwaroo said:
In general, one would go with an Intel based system over AMD when it comes to gaming but in this instance, with your budget and current market prices, the better decision would be to go with AMD in order to budget more towards the GPU.
I would go with the Vega 64, the RTX 2070 is a ridiculously priced card for what it offers over the RTX 2060, and a Ryzen 5 2600 instead of your i5-9600K and RTX 2060.
The Vega 64 basically stomps on the RTX 2060 in most titles:
Total: £918.22
2 minutes ago, paddy-stone said:
i like this build but only issue with it is that i really need to get a rtx 2060 and i cant go above £900 and i dont mind if everything esle is budget since im not going to be overclocking at all and as long is its 16gb rtx 2060 and with a good intel cpu that fine everything else can be budget @paddy-stone
To get the RTX2060, you'd have to cut around £200 from elsewhere, and I don't recommend that you get parts that are mega budget as you'd most likely either have problems, or have to replace them sooner than getting decent parts to begin with. It would be easier to get the RTX2060 with a Ryzen build though.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
