3 minutes ago, anthony man said:
@Slottr and @NickPickerWI would it be smarter to keep the i5 9400 and my gtx1060 and just by a new motherboard and ram casue the transfer to ddr3 to ddr3
You just said you had an AMD FX 4130...
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
23 hours ago, anthony man said:
i know you can only use DDR3  on DDR3 boards. and  i had it from a friend but would it be smarter to buy the board with the gpu i have and the cpu and just buy new ram
...Yes
In topics like these you have to give us all the variables. We don't know what you have or what's going on in your life
yes but i have a i5 to but its am4
Intel chips don't fit into AMD sockets
i know that im just saying i have it but would the board you suggested support my gpu
The AM4 board from what I posted supports the gpu, yes. Any modern consumer motherboard will work with any graphics card (generally). So the only thing you need to "worry" about compatibility wise is between the socket type/chipset on motherboard and the cpu
22 hours ago, quakeguy81 said:
You can buy an FX-8350 for $70 USD new on Amazon right now (probably cheaper used on eBay.)  That way you don't need to spend all your money trying to upgrade.
Thing is though, OP didnt tell anyone they have their hands on a 9400 right now
what would you suggest motherboard wise if i have a i5 4400
22 hours ago, anthony man said:
waht wpuld you suggest motherbourd wwise if i have a i5 4400
What processor do you have? a 9400? a 4400?
Hell, you could throw an atom processor at me right now and I wouldn't be surprised
9400 sorry
Here
Type Item Price
Motherboard Gigabyte - Z390 UD ATX LGA1151 Motherboard $114.89 @ OutletPC
Memory Patriot - Signature Line 8 GB (2 x 4 GB) DDR4-2666 Memory $42.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $157.88
  Generated by PCPartPicker 2019-04-23 23:36 EDT-0400
Here
Type Item Price
  Total $157.88
would there be any complications with anything else switching over to the new board
My bad.  i5-9400 is the way to go.
Literally not your bad haha
They didn't say a word about the 9400
You should reinstall windows, but other than that no.
You might want a new power supply too depending what unit you have currently. Can't imagine it would be too great if youre still rocking a weaker fx system
i have crosair 850 watt
Which model specifically?
Corsair makes lots of PSU models, bro. If its anything like a TXm/RMx then you're all good, otherwise if its a VS-series then I'll be a little bit concerned.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
6 hours ago, Slottr said:
@LukeSavenije Just to bring you back in here. Maybe you have some other input aside from mine, or to combat mine
if he has a microcentre store close, he can get it cheaper
otherwise agree
