So you have a 3GB 1060
You need to buy a cpu
Are you buying a motherboard/ram too? Or do you have a motherboard?
Just now, anthony man said:
no i have everything i just need a new CPU and i already know the socket and all but idk what i should by because i dont wanna buy something and it still be bottlenecked
why not get the best for your money? it's not like a bottlenecked system will perform worse than a worse system
23 hours ago, anthony man said:
no i have everything i just need a new CPU and i already know the socket and all but idk what i should by because i dont wanna buy something and it still be bottlenecked and yes i have the 3 GB 1060 and need a new cpu
Well what do you have? List everything
22 hours ago, anthony man said:
oh okay i dont understand what your asking though about that company
What country are you from? What computer stores do you have near you?
im just gonna buy it online either way and U,S
This is something you can do, it's worth the couple extra dollars over your 200$. Getting something new for your current platform probably wouldnt be worth it
Type Item Price
CPU AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor $116.89 @ OutletPC
Motherboard ASRock - B450M PRO4 Micro ATX AM4 Motherboard $69.89 @ OutletPC
Memory Patriot - Signature Line 8 GB (2 x 4 GB) DDR4-2666 Memory $42.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $249.77
  Mail-in rebates -$20.00
  Total $229.77
  Generated by PCPartPicker 2019-04-23 22:57 EDT-0400
Though check what's in the used market around you
Type Item Price
  Total $229.77
so i need to just get a newer motherboard before i get newer anything
If you wanted to get a Ryzen chip (or any modern chip), you'd need a new motherboard and ram. You can find other AM3 chips, but unless you can get a really good price on a good chip then it's probably wise to spend your money towards something like this instead, imo
However, finding something on your used market is also a really good idea, local classifieds and eBay you can find some pretty good platforms and chips that use DDR3, like a 4790.
@LukeSavenije Just to bring you back in here. Maybe you have some other input aside from mine, or to combat mine
Any local stores like Fry's electronics might be worth a look, you might snag a CPU for like 30% off like I did my brother's
Primary PC:
PSU tier list
How many watts do I need?
I agree with @Slottr. There is no sense in staying with an AM3 motherboard, which is what you have running that FX chip.
With an AM4 motherboard like @Slottrsuggested, you have a lot of upgrade possibility. Eventually, you'll dump the 1060 for something better, and with AM4, you'll be able to upgrade the CPU to something incredibly good at that time without ripping out and replacing your motherboard a second time.
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
am i stupid for asking is there a place for my gpu becasue in the specs it claims that its CPU dependent what does that mean
@Slottr and @NickPickerWI would it be smarter to keep the i5 9400 and my gtx1060 and just by a new motherboard and ram casue the transfer to ddr3 to ddr3
Since when did you get a 9400?
And you can't use DDR3 on any 9th gen board, that I'm aware of.
i know you can only use DDR3  on DDR3 boards. and  i had it from a friend but would it be smarter to buy the board with the gpu i have and the cpu and just buy new ram
