C# Visual studio, %USERPROFILE% not working.
im trying to do
webBrowser1.Navigate("file:///C:/Users/%USERPROFILE%/Downloads
but i get file not found using %USERPROFILE% but using my Account name 5 instead of %USERPROFILE% the path works, so how then can i navigate to file:///C:/Users/%USERPROFILE%/Desktop when %USERPROFILE% does not work...
https://linustechtips.com/topic/1057538-c-visual-studio-userprofile-not-working/
1 hour ago, ughiwanthackintosh said:
im trying to do
That's not what you want to use. It is NOT expecting variable path. You need the exact path. There is no way to get the download folder properly without issues.
First, not all windows version have a "Download" folder
Second, the name changes depending on the OS version (sp : Descargar, fr : téléchargements)
You should use an environment safe folder listed in the Enum : Environment.SpecialFolder.
All folders listed in that enum are language safe and will exist on all versions. you retrieve the full path like this :
var userMyDocumentFolder = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments);
Hey! Let me freshen up my problem, the path C:\Users\5\Downloads works,
but on others computers the folder name will changed based on system name.
example, C:\Users\Emma\Downloads
but on another it might be Jake
im trying to find something like %userprofile% to place in C:\Users\   \Downloads that will work cross system and independent of system name
Get windows currently logged in user. Don't remember by hearth this one.
Just be carefull. For example your code will never run on my computer. First my OS drive is M:\ not C:\ and secondly my user folder is actually redirected on my fourth drive J:\Profiles\Dev\Franck\Downloads\
