Image for Ballistix Sport LT Red 4GB DDR4-2666 UDIMM from Crucial USA
Ballistix Sport LT Red 4GB DDR4-2666(1.2v)
BLS4G4D26BFSE
I have kit of these memories running with my ryzen 5 2600 at 2666mhz. Is it worth OCing it? Is OC even possible with these memories?
if anyone who have used these memories and OCed them could help me out that would be really appreciated! thanks .
https://linustechtips.com/topic/1056956-help-ram-overclocking-for-ryzen/
all sticks, even if they are the same model, OC differently. In fact this applies to everything, there is no "easy settings you could try"
Desktop benching:
Just now, FlpDaMattress said:
Most ram can be overclocked no problem, What are you having trouble with?
image.png.7a4385758493ee037ac1e161c1583a8b.pngimage.png.49a95334d849cc21914c362ca5b64418.png
I want to know how much voltage should I put and what should be the cl? should I just change the voltage to 1.35? and put the oc to 2934 or do I need to change the cl timings too?
Well the first thing I would do is bump DRAM voltage up to 1.35V and then start trying faster RAM speeds with your current timings.  I imagine most timings are set to Auto so they will adjust with the speed and the primary timings set by DOCP seem generous enough to start off.  If you're at 2666MHz you could shoot for the moon and try 3200MHz and then proceed as results dictate.  Or set your DRAM voltage to 1.4V and try 3200MHz with fewer fingers crossed.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
is it safe to go for 1.4? I don't want to burn my sticks (new to oc and stuff)
Those sticks aren't that great to start with, and don't have great heat spreaders. I wouldn't push past 1.35v if it were me.
Intel i7 8700k | Asus ROG Strix Z370-I | NVidia RTX 2070 Super Reference | Corsair Vengeance Pro RGB 3600MHz x 32GB | Samsung 970 Evo 500GB NVMe | Samsung QVO 1TB SSD | Custom Loop | Corsair RMx 850w Gold | Phanteks Evolv iTX TG (modded) | Acer Predator XB1
1.4V isn't gonna harm them.
14 minutes ago, Toheed said:
I increased the voltage to 1.35v and frequency to 3000mhz with same cl timings
You're gonna wanna find a RAM test to run.
I like using TM5 with the 1usmus test profile.
https://www.overclock.net/forum/27577522-post2594.html
Newest version of the test profile by 1usmus:
https://www.overclock.net/forum/27937684-post4314.html
Also HCI MemTest is used by lots and here is a version that will spawn test windows for you:
https://github.com/integralfx/MemTestHelper
