It may show in your microsoft account if you signed in on your last install
https://linustechtips.com/topic/1056324-need-help/#findComment-12496733
Microsoft is actually quite good with things like this if you call them and explain your situation
if at the end of the day nothing works, you can buy cheap keys on ebay or kinguin
CPU: i5-4690k @ 4.4 GHz | RAM: 12GB DDR3 1333MHz | GPU: Sapphire Pulse RX 580 4GB
https://linustechtips.com/topic/1056324-need-help/#findComment-12496778
Where did you get your Windows license?
If you've bought it online, you might have it in your emails/invoice/account.
https://linustechtips.com/topic/1056324-need-help/#findComment-12496782
