troubleshooting HELP MY COMPUTER!
13 minutes ago, NunoLava1998 said:You have a manual. Search for that beepcode in the manual.
Just looked it up, the manual describes that beep code as "Hardware component failure". So that's of little use.
Seeing as you checked the GPU and RAM, it's safe to assume that reseating those won't help.
Make sure the CPU power is connected (the 4+4 pin plug at the top of the motherboard, it's common even for experienced builders to forget that one).
Also try to boot the PC with no SSD or hard drives attached.
Try to boot with just 1 stick of RAM. If that fails, try the other one.
When you go to your friend's house, also try his GPU.
If the PC still doesn't boot without hard drives/SSDs and with his RAM and GPU, the only 2 suspects left are the motherboard and CPU.
