Do you know what radiators you want to use? It matters what size they are.
Primary PC:
PSU tier list
How many watts do I need?
1 hour ago, blinmaker69 said:
2x 280 or (1x 360 and 1x 280) probably from corsair
push configuration
Location and budget? There's quite a few cases that can do it, and quite a few that cant (for example both the Fractal Design Meshify C and the Coolermaster Mastercase H500 can only hold 240mm rads at the top)
Enthoo Pro M TG is $100 USD and can definitely do dual 280mm rads.
umm cooler master h500p mesh or the h500m..  can they support this config?
master case h500 cannot.. i know i just saw a video on that..  Thanks :))
Yes, the H500P Mesh and H500m Come with a 360mm top bracket for radiators, as shown in the exploded view below
Image result for H500P Mesh
