so i ahve never used prime96 so i did today, i have used my OC for about 3 weeks now without a hiccup. i had 17 programs open, cpu was at 56* and i was using 5.2 gbs of ram once. my average is about 5 programs, 3.1 gbs ram and about 29-34* on the cpu. So i thought my overclock was stable, i ran prime95, for about 4 mins, no problems the cpu was at about 54* i left and came back about 1.5 mins later and my system was on the log-in screen, so i assume it crashed windows. Am i doing anything wrong? Thanks for the help :)
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/105445-prime-95-system-crash/
I would close other programs.
Try using the latest Prime95.
If it still crashes immediately then you need to increase CPU Vcore or decrease clock speed.
If you are using the FSB to OC then I would check Ram speed, voltage, and CPU NB voltage.
https://linustechtips.com/topic/105445-prime-95-system-crash/#findComment-1409804
prob should turn down your overclock a little.
i normally would, but like a said, i actually have a yt channel called "aidenscraft" and i did a ram test on there and like i said, i had 17 programs open and my pc dident crash so im fine with the OC, i just shouldent have over 20 cpu intensive programs open at once with rendering at the same time xD
i did the first two things.
https://linustechtips.com/topic/105445-prime-95-system-crash/#findComment-1409832
Did it fail on a blend test or small FFT?
CPU: i7 4770k @ 4.3Ghz with NH-D14 | RAM: 16GB Corsair Vengeance 1600MHz | Motherboard: ASUS Maximus VI Hero | GPU: SLI GTX780 Windforce | SSD: Samsung 840 Pro | HDD: WD Black | PSUEVGA SuperNova 1300W | Case: Fractal Define R4 | Monitor: X-Star DP2710 1440p @ 96Hz | Mouse: DeathAdder  | Keyboard: CM Storm CherryMX Red | Headset: Kraken Pro | Headphones: HE-400
https://linustechtips.com/topic/105445-prime-95-system-crash/#findComment-1409903
