country: austria.
budget: 1000-1100(max peak)
might get the new navi gpus or gen 3 ryzen if they are within my budget and come out within time.
i know i can optimized and go cheaper parts...but rgb...
i have 3 1080p monitors, and play a lot of AAA titles. Decided to upgrade now for the upcoming cyberpunk 2077 game.
thanks.
https://linustechtips.com/topic/1054413-thoughts-on-my-build/
9 minutes ago, Sylthrim said:
I have roughly 1 and a half months before I buy all the parts, so wanting to make sure i have everything planned beforehand.
Chances are the marketplace will change a lot in a month and a half so as for price right now it's fairly up in the air.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479497
How bad of a rush is he on.  Why not wait for Zen 2 and everything will be crystal clear and your prices will fall down.   With a nice OC you will fair well with that CPU with a RX Vega.  Have fun with the build.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479505
yea but i want a general idea of what i want, instead of going in blind. nothing is absolute. if a price goes too high on one item, i just switch it out with something else. Worst care scenario, i drop the aio water cooler, and get it another time.
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479506
like i said, if the gen 3 ryzens come out at the time im buying, i will get one. they will still have the am4 socket, but that is 1 component needed over how many? I didnt research enough on my first build that now i dont want to make the same mistake.
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479513
RX Vega 64 is not a great deal at that price.
nVidia RTX 2060 performs fairly well (wins in some, loses in some but not by a big percentage) and is cheaper and consumes less power. I see the 6GB models for as low as around 280 euro on Amazon.co.uk (converting GBP to Euro).
You can see a RTX 2060 Founder's Edition compared to Vega 64 on Anandtech here: https://www.anandtech.com/bench/product/2143?vs=2372
I'll attach an image below if you're too lazy to look it up.
Besides this ... I'd suggest buying something else, not Toshiba, for mechanical drive. And you could spend a few euro more on a better SSD (more endurance, more TBW etc etc)
RAM is ok, case is subjective, Seasonic makes good power supplies so that's also OK... motherboard is ok. You may want to look more into motherboards to get one with features you want, like usb 3.1 gen 2 (10gbps) or other things.
If you save on the video card, you could probably go for a 2700x, but you could also wait a bit more and see what shows up for Zen 2 (Ryzen 3xxx series)
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479518
I've seen some hubub about this board for RGB at a small savings:
https://de.pcpartpicker.com/product/wb7v6h/asrock-b450-steel-legend-atx-am4-motherboard-b450-steel-legend
But I agree.. See what the 2nd gen market does when 3rd gen comes before you buy. It's likely to drop. (and 3rd gen will be great options.)
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479532
hey thanks for helping. I know about the rtx  2060, was my first choice until i saw that the vega 64 can be really well OC to even compete with a 1080 or a 2070. The vega 64's prices do fluctuate a lot. I saw it as low as 390€. If the vega 64 is too high around the time I buy, im definitely going with an rtx 2060. I am hoping to get a gen 3 ryzen but who knows.
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479537
4 minutes ago, trevb0t said:
thanks for the adivce, but i need wifi+bluetooth, since I use those heavily. i couldnt find a cheaper mobo with wifi and bluetooth
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479545
Noooooo. Just get a pcie or usb adapter for the wireless connections. Those wifi boards are way too pricey for little gain. (Though frankly that one's not too expensive.... Maybe it's a deal! In the US it's a $60 price increase to wifi lol.)
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479550
i noticed that the msi b450 carbon ac is cheaper than a wifi and bluetooth adapter with a cheaper mobo, and i dont have 2 slots filled on my pc.
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479575
Get the vega 64. Wouldn't get anything from Nvidia except 2080 or higher. AMD software alone could convince me, so much better than Nvidias. I have a Radeon VII now but had a liquid Vega 64 before that and it did better than any benchmark out there. I am telling you for a fact, you cannot go by reviews on AMD cards. They do the reviews at launch in most cases and never touch them again. They also don't overclock or undervolt them in most cases. If you don't mind tinkering and playing with some settings, like me, you will FUCKING LOVE that card over any Nvidia card... That I can promise.
My Vega 64 and 2080 hold the record over in the superposition thread, for each cards class. Fastest 2080 and fastest Vega 64. Can't wait until I benchmark my VII. Such a better experience. For me anyway..
And that's coming from someone who stold their 2080 ftw3 for a Radeon VII. Like a fucking  boss. Let the kids have their out of box performance. ;)
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479598
the vega 64 is my first choice, but if the price rises too much i might have to go with the 2060. I havent done much undervolting or oc, but i wanted to start doing that and i want the vega 64 to be my first.
https://linustechtips.com/topic/1054413-thoughts-on-my-build/#findComment-12479628
