First loop problems
Go to solution Solved by ddennis002,
15 minutes ago, ZLing said:
your reservoir/pump outlet/inlet problem. u not connecting any outlet to your pump.
Good catch, your right nothing connected to outlet for pump.
This is my first loop, and pretty ambitious for it. It's a hardline loop with a itx case.
So I finished putting together the loop, filled it up as much as I could pined the two points in the 24 pin connecter, and turned it on. No leaks but no motion in the water. Maybe my set up is bad or i missed something.
Here are my parts list:
Water Blocks:
EKWB EK-Supremacy EVO RGB CPU Waterblock, AMD CPU, Nickel
EKWB EK-Vector RTX 2080 GPU Waterblock, Nickel/Plexi
Reservoir:
Phanteks Reservoir Alum/Copper base RGB LED Cooling (PH-R220_BK01)
Pump:
Swiftech MCP50X Extreme Pressure, Small Form Factor, 12 V DC Centrifugal Pump
Radiators:
Bitspower Leviathan SF Radiator with Quad G1/4" Ports, 240mm, Black
Bitspower Leviathan SF Radiator with Quad G1/4" Ports, 120mm, Black
Case:
Phanteks Evolv Shift X Mini ITX Case Small Footprint Multiple Orientations 360-Degrees of Accessibility Vertical Airflow Cases PH-ES217XE_AG Gray
https://linustechtips.com/topic/1054354-first-loop-problems/
You don't have to turn anything on other than the pump to get the water to move.  I would suggest only powering your pump (I just did my first loop 2 days ago) with the PSU till your levels are good (which is what I did using a molex to 3 pin).  If you build it and turned it on and nothing happened with the mobo...is your PSU on or plugged in (I mean it not being a jerk, and if so you may need to breadboard your build.  Or did it function correctly the first time before you put in the loop?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12478896
1 minute ago, Sansevieria said:
The PSU is plugged in, when I turn it on the pump moves but the fluid doesn't
Im a noob to closed loops but - is the pump primed?  If there is no fluid in the pump to push, it wont do anything but spin I would assume
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12478907
3 minutes ago, Sansevieria said:
The pump looks primed, I included photos
Check wiring for the pump can you feel it vibrating? You should hear it just barely if you put your ear close to it, at very least you should feel the pump running. Could have a bad pump. It happens.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12478926
I can definitely hear it when it's turned on. The pump spins too
Does that pump have speed control on the pump or is it PWM?
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12478941
5 minutes ago, Sansevieria said:
It doesn't have speed control, but it is PWM
did you cap the fill port before you turned the pump on? Also without a PWM signal the pump will run at its slowest setting you may have to hook it all up and prime the system with so the pump runs faster.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12478971
2 minutes ago, Sansevieria said:
I've tried running with the cap on and off. So if it is PWM, I would need to plug in the entire system to test it?
Yea, just power the system on and the pump will run full speed, it should only take seconds to drain the res. If it still don't move will have to try to gravity feed the loop there just maybe to much air in the system for the pump to over come.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12478997
It mentions on the amazon page that if the 3rd pin is not connected it will run at full speed
The pump has sata power connector, does it have 3pin or 4pin style fan connector?
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12479005
Yes so if it is connected to 3 pin headed it will run full speed, but that connector has to have power from the board or you have to have an adapter 3 pin to molex or sata. If only the SATA cable on the pump has power the pump will run at its lowest possible speed.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12479032
Go in the bios and set the speed to max.
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12479165
probably an airlock.
Start tilting and moving it around
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12479461
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1054354-first-loop-problems/#findComment-12479864
