I'm pretty certain that they have to use the same GPU core.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
The cards have to utilize the same core, but they can differ in the number of SPs and amount of VRAM. The R9 380 and RX 570 use different GPU cores from different generations, so it's a no-go.
Your R9 380 can crossfire with another R9 380 or an R9 380X, since they both use the Antigua core. The RX 570 can crossfire with the RX 470, RX 480, RX 570 and RX 580 since they all use the Polaris 20 core.
I believe there are some cases where you can make it work with mis-matched cards but ideally you want them to be identical. What you're getting out of the 2nd card is the compute power and if it's going to split that load with the primary GPU you'd want it to be just as capable. With sufficient VRAM too.
RX 590 too i guess?
  • 3 years later...
