I'm going to get a new gaming pc soon with a budget of around €750-€800 ($844-$900). Mostly just for performance (can add some rgb stuff later if I want to). I think I know what parts to use for it:
Ryzen 5 2600 (w/ stock cooler), b450 aorus elite, aorus rx 580 8gb / gtx 1660 (not sure yet), 16gb ddr4 3000mhz, corsair cxm 550W 80+ bronze psu semi-modular.
But I still don't really know what case I should buy. I have a case budget of around €60 ($67,50) and I just want ok temperatures for cpu and gpu. Cable management is less important for me.
I've seen these two options so far:
  • Cooler Master mb511, which is great for airflow, and looks ok, you get 3 rgb fans.
  • Corsair carbide spec-05, (don't know if it has enough mesh for airflow) , only 1 fan, acrylic side panel.
Can you guys help me with finding a case (can be m-atx as well, then I'll pick another motherboard)? Or give me some advice? Other tips or recommendations are welcome as well.
Thanks in advance.
https://linustechtips.com/topic/1053799-need-help-for-a-pc-case/
mb511 rgb? great choice
focus g is pretty good too, but comes with white fans
if you want something a little more expensive you could get a meshify c/s2 or cooler master h500
Ben nederlands btw xD
Thanks voor je antwoord
They also have the MC500 and K500 which would be good as well.
https://nl.pcpartpicker.com/product/6qPKHx/cooler-master-masterbox-mb500-atx-mid-tower-case-mcb-b500d-kgnn-s00
https://nl.pcpartpicker.com/product/9CCD4D/cooler-master-masterbox-k500-atx-mid-tower-case-mcb-k500d-kgnn-s00
PCPartPicker only has Paradigit listed for their filters so I'm not sure if there are other sites you can buy from that might have better deals. @LukeSavenije being a fellow ?netherlandian? can probably help you shop for the best price.
Just now, LukeSavenije said:
Nederlander...
¯\_(ツ)_/¯
I'm an uninformed American. I cant help it :D
