Hello everyone,
i'm new here, so if i created a wrong topic in a wrong section, please tell me.
I like to use all PC peripherals without cables, be it controller or mouse+keyboard. The keyboard, which i use every day is Varmilo VB87M and while it feels nice to use it in system, it's a bit annoying when you can't use it in BIOS, so i'm interested in making it work in that part of a computer too.
I've done some research here and there, and found that you need a Bluetooth adapter/dongle, which supports HID proxy mode. I've also found that Laird company produces 5.0 and 4.0 Bluetooth adapters and assures you that they both support HID and HIC modes. Now, i have some experience about Bluetooth adapters, but this is the first time i hear about these modes, so if anybody has any experience with Bluetooth adapters and how they work, i'd appreciate any kind of help in this task.
https://linustechtips.com/topic/1053649-using-wireless-keyboard-in-bios/
I don't think anything wireless will work in bios
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
If your keyboard has a wired mode, try it and see if it works. My k63 wireless does the same thing. Remove the wireless adapter and/or disable Bluetooth and plug in the charging cable.
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
Unfortunately, its wire is only for charging the keyboard. I've tried to find some way to make it register through USB, but i guess, the keyboard lacks something on its PCB, so there's no other way of using it, except Bluetooth.
I've contacted Laird about their claim and still waiting for their answer.
Bluetooth won't work, RF on the other hand should. If it requires an RF dongle it should work. Bluetooth devices usually require some drivers to be loaded first, which usually won't work. My wireless mouse for example does work perfectly well in RF mode in BIOS.
Use the quote function when answering! Mark people directly if you want an answer from them!
I've done some digging and i found that apparently Apple implemented the support for using Bluetooth keyboards in BIOS through D-Link DBT-120 Bluetooth adapter. To use HID proxy mode and use your Bluetooth devices in BIOS, you need to flash an adapter, but the problem is that this same adapter works only with iOS.
For anyone's interested, here's an information file of Laird's dongle, which has instructions to install and switch modes between HID and HIC:
https://connectivity-staging.s3.us-east-2.amazonaws.com/s3fs-public/2018-10/Application%20Note%20-%20BT800%20Series%20HID%20Proxy.pdf
