I'm planning to buy a gaming rig around $1000. Is this a good build or are there any improvements that I can make to this particular build?
CPU: Ryzen 5 2600
Motherboard: MSI B450 Gaming Pro Carbon AC
Memory: 2666MHZ Corsair Vengeance LPX 16GB(2x8)
Storage: 2TB Seagate Barracuda
GPU: Gigabyte RTX 2060 Gaming OC
Case: NZXT H500 Black
PSU: Corsair RM550X 80+ Gold
Also, is it worth building a pc now, considering the fact that supposedly the ddr5 ram and newer gen cpus are coming later this year?
https://linustechtips.com/topic/1053322-rtx-2060-build/
nah, not even servers are using DDR5 yet. Those usually get half a year (at least) head start before consumer platforms.
3rd gen Ryzen was supposed to be launched in July? Later this month the architecture is expected to announce in Computex so if your current system is bearable, don't build yet. If it's slow and awkward, get something you can reuse later like an SSD, a cooler etc.
Desktop benching:
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12468503
CPU: Ryzen 5 2600
Swap 2TB HDD for a crucial mx500 (personally only use the Samsung drives) and add additional storage.
HDD’s are way way way too slow compared to SSD’s
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12468530
AMD is supporting AM4 Socket until 2020 so DDR5 for Ryzen based cpu's until then at least.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12468540
So should I wait for the ryzen 7's prices to drop when the 3000 releases? Or should I just buy a ryzen 5 or 7 now?
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12468624
Just now, Daddiee said:
I was planning to buy an ssd after ive built the pc
Why? It just does not make sense dude.
you have a grand budget, better start with a SSD. Add additional storage after in my opinion.
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12468625
Can you wait?
if so, then wait will be my advice
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12468628
5 hours ago, LukeSavenije said:
Is it worth it to get a gpu that expensive? I was thinking of getting an rtx 2060 so that I'll save much more.. well, thats the life of a college student for you
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12469457
oh then, i thought because i had some budget left, i would add in a nicer gpu. but if cheaper=better, be my guest to this one
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12469473
CPU: Ryzen 5 2600
Apart from the lack of SSD as already mentioned, that is a solid build. Maybe go with 3000MHz - 3200MHz Ram but otherwise a good spec.
https://linustechtips.com/topic/1053322-rtx-2060-build/#findComment-12469501
