I have a 10 year old q6600 G0 CPU, still works fine but its time for an upgrade.
Should I go with 3700X or 3850X? Is 3850X a waste of electricity bills and not worth the increased performance?
Should I wait even further into the next generation of Zen?
I will be doing mostly video editing, music, and VR for racing games.
I have a HD7850 that I will keep unless I see necessary to upgrade.
PSU is Enermax 720W... I will keep it, still very solid.
Case Fraktal r4, also will keep it.
I will not be using Intel ever again. Too many NSA exploits clusterfuck histories and too expensive and electricity consuminga anyway fuuck them
https://linustechtips.com/topic/1052972-upgrade-advice/
Time to upgrade the platform, I'd say. You can get on Ryzen for fairly cheap and it will definitely offer you a good performance boost.
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12465214
Time to upgrade the platform. Just go for a Zen 2 Ryzen 5 I guess, it will be fine for anything now and you can always upgrade to Zen 3 in the future.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12465240
Yup. Go for a B450 Motherboard with a Ryzen 7 2700x or cut it down to a Ryzen 5 2600 and then get a bios update and go for a Zen 2 chip when they come out.
Home Base : Ryzen 5 2400G - ASROCK HDV R4.0 B450M -  Corsair Vengance Pro RGB 2x8GB @3200Mhz - Sapphire Pulse RX 5700XT - WB Black (2018) 500GB NVME SSD - 250GB WD (P.O.S.) HDD - 250GB LITEONIT SSD - Cougar MX330 ATX Tower - EVGA SuperNOVA 750 GQ 750W Gold- Razer Deathaddder Elite - Corsair K55 RGB Keyboard
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12465267
Yes, Zen 2 Ryzen 5 will be great for now and then just pop in a Zen 3 when you can upgrade next.
I am probably a nerd that loves tech.
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12465462
BTW... when I say Zen2 I mean Ryzen 3000, not Zen+.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12467519
Is this leak legit:
AMD-Ryzen-3000-Zen-2-CPU-Price-Specs-Lea
I saw other leak where 3700 was around $350... do you think it's worth it vs 3600X to pay an extra 100 bucks?
Also can u explain what X and G mean?
Edit:
https://wccftech.com/amd-ryzen-3000-cpu-specs-prices-online-retailer-ryzen-9-3850x-leak/
Here can you can see a table that says "rumored" and you can see "AMD Ryzen 7 3700X12/244.2 GHz5.0 GHz105WN/A~$370 US"
This is good price, $370 still on "makes sense range". For me when it goes into $500 range it starts becoming pointless, but I would still pay $370 bucks for a CPU considering i've used mine for 10 years. And I will be doing CPU intensive stuff like opening many instances of VST in Cubase or FLstudio, as in many reaktor 5 instances which consume CPU, so an extra would be good.
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12467522
2 minutes ago, Windows95 said:
Is this leak legit:
We don't know if it's legit. I'm not a crystal ball.
$455 SGD is $370 USD.
X = XFR on, basically a really high turbo boost.
G means it has integrated graphics.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12467527
Oh I see. Well I hope its the real price, I would go for that one.
Is those "turbo boosts" safe long term? consider I used my CPU for 10 years. Those "boosted" CPUs make me paranoid that the long term life expectance is reduced so I see it as a bit of a scam.
So now I just have to decide if 3700 or 3700X...
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12467535
Well... it's turbo boost for a reason. Your CPU is already running hot at load, so it
does some fun tricks to make it run even faster.
If it died sooner, then the CPU companies would not implement it, since it'll leave a bad taste in consumers mouths.
Just overclocking it yourself though usually saves a bit of money.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12467598
Ok I'll go with 3700X then
Can you then recommend me a MOBO to go with it? one that ideally has:
-no wifi
-no bluetooth or any other wireless bullshit
-will be able to take future CPU's in case of update (Zen3 i guess)
then, DDR4 ram, 16 GB should do, an SSD.. oh and a silent fan for the CPU cause I do music and hate background sound. Which noctua would work with the MOBO and fit inside a fraktal r4? thanks for input
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12467760
-no wifi
Well, the X570 boards aren't out yet, so I'd recommend you choose a board then. When 500 series/Zen 2 is out, you can also use current motherboard, FYI. Ask again when you buy.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1052972-upgrade-advice/#findComment-12467767
