Best choices for AM4 motherboard
Go to solution Solved by onlybuilt4cubanxlinx,
Good afternoon everyone.
I'm building a PC for a friend and now i have to choose a motherboard, ATM he's going for a 2600X and he probably will update for Ryzen 2 (7nm 3000), but i'm trying to choose which motherboards, could you guys help me?
I know about VRM and this kind of stuff, but the price of all of them are almost close soo... there's my doubts.
The models i'm in doubt with are these:
ASUS:
ASUS PRIME X470-PRO
MSI:
MSI X470 GAMING PLUS
MSI X470 GAMING PRO
MSI X470 GAMING M7 a litte bit more expensive
AORUS
GIGABYTE AORUS X470 AORUS ULTRA GAMING
I was looking for the Gaming 7 wifi, but it's out of stock everywhere here in my state(São Paulo, Brazil)
Asrock:
ASROCK X470 MASTER SLI
Taichi is way more expensive and it's out of the question
BIOSTAR
X370GT7 or the X470GT8
PS: He'll probably do some overcloking with my help and wanted this board for at least a couple of year and if possible to use it with a "possible" Ryzen 7 12C/24T.
So in this case which one would be better?
"Once there was an explosion, a bang that gave birth to time and space. Once there was an explosion, a bang that set a planet spinning in that space. Once there was an explosion, a bang that gave rise to life as we know it... And then came the next explosion. An explosion that will be our last"
"... To see the world in a grain of sand. Heaven in a wild flower
Hold infinite in the palm of your hand.  And eternity in an hour ..."
PC: 1
CPU: AMD Ryzen 9 3900X 4.3GHz 1.3875v Motherboard: AsRock X470 Taichi (BIOS: Agesa 1.0.0.3 ABB) RAM: 4x8GB(32) 3200MHzCL16 Hyper X GPU: GTX 980 Ti Waterforce Xtreme Core Clock: 1595MHz Memory Clock: 8000MHz Storage: SAMSUNG EVO 860 2TB(OS) / SAMSUNG EVO 860 1TB(Backup) Cooler: NZXT Hydro X72 360mm Case: NZXT Phantom 820 PSU: Corsair TX-750w Display Monitor: Monitor AOC AG251FG 240Hz G-Sync 1080p Headset: Headset LogiTech G633 OS: Windows 10 Pro 64-bit (Version: 1909 / OS Build: )
NOTEBOOK:
Model: Acer Aspire 5516 CPU: AMD TF-20 1.6GHz(1C/1T) GPU: ATI Radeon X1200(256MB) RAM: 4GB(2x2GB) 666MHz HD: SSD Sandisk PLUS 240GB OS: Windows 7 Ultimate SP1 x64
1 minute ago, onlybuilt4cubanxlinx said:
Explain how the x470 Gaming K4 is worse off than the B450 Gaming K4? My VRMS never touch 80*C with my 2700x @ 4.2GHz 1.4375V where my X470 Prime did frequently
MSI B450 Gaming Plus AC. Best price to performance right now, despite MSI's, ahem, difficult BIOS. I have the X470 Gaming Plus, which is also a very good board, and shares a lot with many of the better B450 and x470 boards that MSI makes and has handled a 2600 at 4.1 with ease, and the B450 Gaming plus is arguably a better board than this one.
Also, I'm in no way an MSI fanboy, this is the first MSI board that I've bought in over 10 years because that one was junk. However the value on these boards is just much better right now than many other brands, despite their BIOS which I frankly HATE for advanced overclocking with precision boost. Manual overclocking is fine, just don't use their command center to do it. I have found that their standard precision boost is not as aggressive as others.
has vrm thermal problems, is the fatal1ty available?
ASUS PRIME X470-PRO
is okay-ish
MSI X470 GAMING PRO
are okay-ish
17 minutes ago, GabrielLP14 said:
MSI X470 GAMING M7
better... is the pro carbon there too?
pretty good
6 minutes ago, RobFRaschke said:
... and has handled a 2600 at 4.1 with ease...
that's like saying a car is so good it can easily hit 20 mph.. lol
literally every am4 motherboard, probably even 2 dimm ones can do that
15 minutes ago, onlybuilt4cubanxlinx said:
Thank you very much but like i said, Taichi are too much for him and the ASUS is out of stock the same as the AORUS GAMING 7 and the MSI M7 AC is also above his budget.
PC: 1
NOTEBOOK:
Unfortunately no, i also looked for that model :(
PC: 1
NOTEBOOK:
6 minutes ago, hello_there_123 said:
b450 tomahawk
Has to be a X470
PC: 1
NOTEBOOK:
is okay-ish
are okay-ish
pretty good
The 470 gaming plus, x470 gaming pro and b450 gaming pro carbon all use identical VRMs. The X470 gaming pro carbon is minimally better IMHO having one extra channel of identical design to the others. The X470 Gaming M7 however is by far the best VRM that MSI has, and IMHO, second only the 470 Gaming Taichi from ASrock. The B450 Gaming Pro is actually a better VRM than anything but the X470 Taichi, the Asus Crosshair Formula and the x470 gaming m7. It actually uses the same VRM components as the Strix X470 board, but I like the physical layout slightly better, though in function, they're likely interchangable and the Asus definitely has the better BIOS.
1 minute ago, GabrielLP14 said:
Has to be a X470
How come?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Thanks for the information. I'll try to look for the M7 AC but i doubt i'll find it inside his budget. Because only remains the MB to buy.
PC: 1
NOTEBOOK:
2 minutes ago, LienusLateTips said:
How come?
Because they could have better VRM that some B450 although some X470 has the same VRM as some X470
PC: 1
NOTEBOOK:
Not with VRM temps that have never seen 70C and don't hit 60C during a Cinebench R20 run.
That's absolutely not true in every case. The MSI B450 Gaming Plus has one of the best VRM on the market IMHO, better than MANY of the midrange or lowend X470 boards, and it typically runs $120 here in the US.
Not really unheard of either... that's like testing how good CPU coolers are on a pentium lol, of course you will have excellent temps
the only thing x470 is good for is extra usb ports which most people don't need
And CrossFire/SLI, which most people don't use either.
Incorrect, because like i just said, some models have the same components in the VRM in both B450 and X470.
PC: 1
NOTEBOOK:
So between those i've quoted in the first post, which one you guys think i'd recommend him?
PC: 1
NOTEBOOK:
I'd go for the ASUS X470-Prime since it's got a better VRM and it doesn't suffer from MSi's BIOS... difficulties. That said, either one is fine
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
Duly noted, and thanks for the Reply.
Anybody else?
PC: 1
NOTEBOOK:
UPDATE:
I told him about the M7 AC(MSI X470) and he agreed to sell one of his many 120mm FANS in order to get that motherboard.
Thank you everyone, you guys rock:
@OrbitalBuzzsaw
@RobFRaschke
@hello_there_123
@LienusLateTips
@PC Budget Solutions
@onlybuilt4cubanxlinx
and old friend @LukeSavenije
PC: 1
NOTEBOOK:
9 minutes ago, GabrielLP14 said:
UPDATE:
@OrbitalBuzzsaw
@RobFRaschke
@hello_there_123
@LienusLateTips
No problem. By the way, try and keep the mass @mentions to a minimum, since it gets annoying when scrolling through long notification screens.
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
