Every single AAA title I have tried to play on my new pc fails miserably. Metro Exodus is no exception I tried running the game with vsync on ultra frame drops and input lag were crazy. Changed it to high same thing. Turned off vsync and the frame drops continue as well as the game being a stuttery mess I dont get what the problem is because the game does not have any drops below 70 well running but will drop from 100 to 70. Is this a problem with my computer or just the game?
https://linustechtips.com/topic/1052005-metro-exodus-frame-drops/
How would I know if I have no idea what computer you have.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
Whoop sorry i have a core i5 8400 16 gb of ram a vega 56 running the game off a crucial SSD and have a 75 hz monitor.
Have you checked your temperatures? RAM/CPU/GPU usages?
2 minutes ago, Carz728 said:
Yeah cpu is at 49 degrees gpu around 70. Cpu running at 60 to 80% and gpu running at 90-99.
What about RAM? Is your system registering all 16 gigs? Is it running at full speed?
Yes, its running the 16gb at 2100mhz. Which is the right speed.
That is very slow for DDR4 RAM.
Starting to think it is just my monitor. Is this a possibility?
Its not your monitor unless you're having frame skipping, then it would be happening 24/7.
Have you tried switching between DX11/DX12?
No, but I have heard that dx11 runs better which is what I am running it at. I recorded a video and the gameplay looks fine the lag that I am experiencing is not showing up in the video.
Here is the video here https://drive.google.com/open?id=1I4IrobDEC78BPzUANo0wUzE8KWd-bv7x
8 minutes ago, Carz728 said:
Try switching to DX12.
List full system specs.
CPU, MB, RAM, PSU, HD, Monitor etc.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
