I have a budget of around $150 and need a white z390 rgb motherboard. The reason is I'm going with a white and purple rgb build.
This is my build so far.
https://linustechtips.com/topic/1051380-need-a-white-z390-motherboard-with-rgb/
Primary PC:
PSU tier list
How many watts do I need?
16 hours ago, Jr SavageZ said:
Is it that easy to paint a motherboard?
yeah, in the modding section, there is a pinned guide.
You just take off the heatsink (if you want to paint those, I'd recc only painting the plastic parts), mask off anything that you don't want to be painted and all wiring, some cardboard + paint.
for the VRMs, ASUS from their cheapest boards to their Maximus XI hero and formula are using just a 4 phase, with double the components without doublers. while others (ASRock, Gigabyte, MSI, EVGA) are doing 10 and 12 phases with doulbers
And you recomend which one? But you dont know any good white ones?
Do you know if you can change the gif on the nzxt cooler like the Asus one?
