I need to use internet recovery but it doesn't work with ethernet (my wifi chip is broken/missing)
Solved by Silentprototipe,
13 hours ago, Jacobtechtips? said:If i get what your saying is that i should use my phones hotspot...the wifi doesn't work as i got this laptop cheap and it was missing the wifi/bluetooth ribbon cable.
Not particularly, I meant plug your phone into the laptop, Then activate USB tethering. Most laptops will recieve it was an ethernet connection
