My computer (desktop, 1500x & 1070) was working about 10 minutes ago and then I turned it off and when I attempted to turn it back on there are no signs of life. No fans, lights whine, nothing. I've had some issues with it before, but those were always with posting, not just doing nothing.
https://linustechtips.com/topic/1050663-computer-not-starting/
check to make sure none of the power cables have come loose, and makesure the PSU input is firmly plugged in
 Main Desktop
CPU: Intel Core i7-14700KF
CPU Cooler: Arctic Liquid Freezer III A-RGB
MB: ASUS ROG STRIX Z790-F Gaming Wifi II
RAM: 32GB(2x16GB) Team T-FORCE Delta RGB 6000MHz DDR5
GPU: ASUS ROG STRIX RTX 4070ti 12GB
STORAGE: 2.048TB Kingston KC3000, 2TB Crucial T500, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Montech King 95 Pro
PSU: Be Quiet! Straight Power 12 1000W
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
https://au.pcpartpicker.com/user/johnno12/saved/4HDc4D
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
https://linustechtips.com/topic/1050663-computer-not-starting/#findComment-12446180
Just now, en1gMATIC said:
i did that already
have you tried reseating the cables, checked for any damage to cables?
Also makesure there is no shorting happening.
Is there nothing happening when you press the power button on the case, if not try using the button on the motherboard or if there isn't one try shorting the power pins.
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
https://linustechtips.com/topic/1050663-computer-not-starting/#findComment-12446188
1 minute ago, en1gMATIC said:
its one of those weird ones that doesnt have a switch
turns on with the power button
what model PSU do you have
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
https://linustechtips.com/topic/1050663-computer-not-starting/#findComment-12446207
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
https://linustechtips.com/topic/1050663-computer-not-starting/#findComment-12446216
after reinserting all the important cables it appears to work
thanks for the replys
no worry's
I've had a similar thing happen, sometimes the cables look to be in properly but aren't quite making contact. can be quite scary tbh
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
https://linustechtips.com/topic/1050663-computer-not-starting/#findComment-12446220
