PWM or DC mode
Solved by WoodenMarker,
9 hours ago, ShadySocks said:DC mode on a PWM fan won't damage it.
Except on ML's which require 12V for the magnetic levitation to work properly.
7 hours ago, Winter_German said:It was just weird that only the rear one changed, and it wasn't running at its true 50% when I set it there.
The signal to rpm curve varies between different fans and different methods of delivering power. For ML's you shouldn't be using DC in the first place.
