country: Austria
budget: 1k peak 1.1k
uses: gaming
what I have now: 3tb hdd, 250gb ssd, 3x 1080p monitors. mous/keyboard.
here is the building i am working on. Suggestions greatly appreciated.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/
If you're comfortable manual overclocking, the 2600 and 2600X are absolutely identical, save the few bucks. Rest looks good enough if you like it. I don't love that powersupply, especially for that cost. It's on-par with others in the same price-range, but not in any way astonishing. Are there others which are cheaper which are similar?
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440453
10 minutes ago, Sylthrim said:
country: Austria
uses: gaming
good choice going with the 2600x!! but why such an expensive graphics card? what will you be using it for? And have a look at the pricing for an EVGA 650W power supply, personally like them better.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440455
uses: gaming
Check out this build:
Just now, CHRISTIANT6 said:
but where is your hard drive/solid state drive and what will you be using this pc for?
Have you read the post at all? The OP literally answered all of those questions.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440457
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440459
The 2600 and 2600x were so similar in price that I just went with the 2600x to save money on buying a new CPU cooler. There were better ones, but I wanted modular or semi-modular.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440461
5 minutes ago, CHRISTIANT6 said:
good choice going with the 2600x!! but why such an expensive graphics card?/ what will you be using it for...
I'm going for an rgb look, so I went with an msi rgb card. I went budget pc my whole that I want to spend a little more this time to make it look nice.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440468
thats the one that dosnt come with a cooler tho?
Builds:
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440469
Completely fair!
I'll second the Tomahawk recommendation though, that's a substantial price difference and I doubt you'll notice any difference aside from visually.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440472
2600x comes with wraith spire.
2600 comes with wraith stealth.
Both are sufficient for out of the box speeds. The spire will have definitely better thermals at 4ghz all core. Neither can touch a hyper 212 or the arctic cooler.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440478
Completely fair!
Yea but the carbon one comes with a WiFi antenna and 5.0 Bluetooth. Would you recommend the tomahawk still? I was thinking about that one too.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440485
Not if you actually need the wifi or bluetooth. External cards are annoying and can take away from the aesthetic. And bluetooth external sticks and cards are never very nice looking.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440490
4 minutes ago, Sylthrim said:
1080p for now with 60hz, but I want future proofing, and saving for a 1080p 144hz monitor in the future.
sounds like a great build! personally id get an nzxt h500/h700 as i think its a lot cleaner look and an asus tuf gaming x-470 motherboard just because of overclocking for good frames on gaming, but that will be fine!!
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440492
I have 4 Bluetooth earphones/headphones, and sometimes use my phone as internet when my home internet is acting slow. Im using a cheap WiFi and Bluetooth USB adapter right now.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440495
15 minutes ago, r2724r16 said:
Spend a bit more on the psu. A Bitfenix Formula 550W Gold would be a better option. You get an actual warranty with it (5 years) instead of a lousy two years.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440497
Thanks haha. I wanted something flashy and obnoxious this time around. Maybe on my next build I'll try something clean.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440500
So if I don't get rgb and go cheap with everything, I can get a 2070? Is it worth it? That is tempting.
Not for 1080p, if you FPS at 1440p or want to get into 4K gaming other than sim games, it would be.
The MSI boards actually overclock really well. I'm on an MSI x470 Gaming Pro which shares VRM design with both the Tomahawk and B450 gaming pro(not the other gaming board, the gaming plus?) and I'm at 4.1ghz all core on my 2600 non-x 24/7 stable with a 240mm AIO.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440502
i personally like asus more, but the msi would be good, just my mate has had bad experience with b450! just not as good apparently. but hes got a ryzen 7 2700x so bit different
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440511
The Asus X470 TUF is awful.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440518
26 minutes ago, r2724r16 said:
Thanks, but someone pointed out that a 2070 would be overkill at 1080p. Also, im going for an rgb vibe this time around.
https://linustechtips.com/topic/1049955-thoughts-on-my-build/#findComment-12440520
