Hi all,
I have a FD Meshify C and currently I have two Arctic P14s as intakes in the front, an Arctic P12 as exhaust in the top and a Corsair H75(2018) with a push/pull configuration as exhaust in the back.
The top fan is right above the CPU and I could in theory put another Arctic P12 I have laying around also in the top. My question is would this be useful at all? If I do that then the air coming in through the top 140mm intake would be exhausted again straight away by the top fans meaning the air doesn't really get to the radiator in the back right?
I feel like having it as an intake probably also won't do much good; even though it would blow on the back of my GPU I am guessing it would just pull in the hot air that was exhausted by then fan next to it.
Any ideas?
Should I just leave it open or do I still install a fan in that open slot?
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/1049795-help-with-fan-setup/
Not sure if I understand you correctly, but it sounds like you want to have both exhaust and intake fans on the top, no? If that is correct, that would defeat the purpose of having top mounted fans. You would want to have both of your top fans as exhaust. General rule, front and side fans are intake, top and rear are exhaust.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1049795-help-with-fan-setup/#findComment-12439101
Yes exactly. My main question is whether it makes sense to put two fans in the top, since I fear they will just exhaust the air coming in through the front fan before it even reaches any components. Is there any reason to have two top mounted exhaust fans if there is no radiator in the top?
My System:
https://linustechtips.com/topic/1049795-help-with-fan-setup/#findComment-12439104
Generating airflow throughout the case gives a nice breeze over your motherboard, radiator, etc. This also helps eliminate heat building up inside your case which can eventually lead to "heat soaking" (more of an issue on air coolers).
PC #1
PC #2
Corsair H80iGT AIO
Laptop
https://linustechtips.com/topic/1049795-help-with-fan-setup/#findComment-12439109
8 minutes ago, StarsMars said:
My ms paint skills. This is what I'm thinking.
Awesome pictures!
So the third intake fan in the bottom would in my case basically be cooling the back of the PSU, since it would be for the most part beneath the PSU shroud. This is why I went for two 140mms in stead of 3 120mms. Right now the "idea" behind the airflow is that the top 140mm blows air over the motherboard and towards the CPU radiator in the back, while the bottom 140 blows most of it's air over and under the GPU. It's that short top 'draft line' in the last picture that doesn't seem very useful to me and makes me wonder whether it wouldn't be detrimental to the airflow if I were to throw in a second fan in the top.
My System:
https://linustechtips.com/topic/1049795-help-with-fan-setup/#findComment-12439145
2 minutes ago, martward said:
Awesome pictures!
So what I think the "problem" with the set up labeled turbulence that is misspelled..is that you want air to be flowing in over the components and out. The turbulence impedes the flow of fresh air. This is all just me talking though. I have a PHD in BS.
Chances are there won't be a noticeable difference. There is no reason to not throw it on if you have an extra fan sitting around.
Stick it on and record your temps. Would be interested to see what happens.
https://linustechtips.com/topic/1049795-help-with-fan-setup/#findComment-12439159
Yeah the turbulence setup is not one I'm considering. I have the first setup now and am trying to figure out whether the last one makes sense.
My System:
https://linustechtips.com/topic/1049795-help-with-fan-setup/#findComment-12439198
1 hour ago, LoGiCalDrm said:
Whats the reason why you are looking to switch things around? Temps?
Well my GPU temps are a bit high, around 75C under load. But it's part slightly improving temps, partly that I have a decent fan lying around doing nothing and partly plain curiosity.
My System:
https://linustechtips.com/topic/1049795-help-with-fan-setup/#findComment-12439778
