Do i need to use an antivirus for hackintosh?
Solved by TheKDub,
11 hours ago, Rehnee said:Assuming that it's less common, does that also apply to the hackintosh?
Hackintosh is generally just MacOS running on a non-Apple device. Aside from possible hardware vulnerabilities, it's not much different from the real thing virus wise.
