Just taking apart my old Dimension E520 for the first cleaning in 13 years. I've had it since 2006, and it was used before I got it as an office PC.
BUT IT STILL HAS THE SAME PSU. It's still running the same Sparkle 400w PSU that it came with. No squealing, no sparks, no overheating. I really can't believe it.
So what's the longest you`ve had a power supply last?
Asus Crosshair VII Hero X470
Ryzen 1800X - 4.2ghz @ 1.435v
Deepcool Gamerstorm Castle 360 RGB AIO
Corsair HX1000w
Thermaltake View 71 case
Corsair M65 Elite mouse
Redragon K551-RGB keyboard
RGB out the wazoo = good for at least 420fps in Crysis
https://linustechtips.com/topic/1049348-longest-running-power-supply/
The PSU in my OG Prebuilt Dell PC from the late 90s is still running fine.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
It probably doesn't count, but my friend's first PC's PSU became mine, which I used for 3 years so that's about a 6 year operating life, now it's in his closet again as the backup PSU among us. It has a weird quirk where it will restart whatever system it's connected to when you power it off, so to actually turn your PC off you have to power down normally then flip the switch. It also wakes a PC from sleep, pretty annoying.
I also have an HP server with its own original PSU, idk how old that thing is though.
Primary PC:
PSU tier list
How many watts do I need?
It seems like the older a power supply gets, the more likely it will run forever lol... I used to have an IBM 5150 which I'm pretty sure was all original but I never opened it. Just got tired of it taking up room and threw it in the trash (I know, you don't have to say it).
Corsair HX1000w
Just yesterday I read somewhere about someone else having the exact same problem. I don't remember if it was on these forums or not. Definitely a weird occurrence. Maybe a relay?
Corsair HX1000w
For me, that'd technically be the Macintosh Performa 5200, the first computer that my family ever owned. I believe it was from 1996, when I would have been around the age of 10. She hasn't seen any use at all in nearly two decades though, but she does still work.
Outside of that, I've got an old Antec unit from ~2010 that I use for testing pumps and whatnot.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
  • 1 month later...
My current pc has an Enermax unit I bought in 2009. It was used for bitcoin mining back then for about a year before they dropped down to only a couple bucks. (if only I had bought a bunch) It's currently powering an overclocked 5830k and 1080 with voltages staying at or above 12v. Enermax and Seasonic are my goto brands for high quality.
For me its servers, in my previous job we had a lot of early model Dell Poweredge 1950's and HP DL360 G2's they just ran forever.  A pair of DL360 G2 ran the DNS since 2001, they were ancient Pentium 3's but they just kept going.  I still have drinks with the guys and we laugh that they still use the same two servers since I left without any hardware failures.  So there's 18 years.
They really don't make them like they used to!!
I have two PC's from the 80's. Amstrad PC 1640 and Commodore PC 10-III and I think they have the original PSU's.
Intel Core i9-9980XE 18c/36t, Asus TUF X299 Mark 1, 128GB DDR4 3200MHz, Palit RTX 5070, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, Meshify 2
PC 2: AMD Ryzen 7 3700X 8c/16t, MSI X470 Carbon, 32GB DDR4 2666MHz, Asus GTX 1080 Strix, 512GB Samsung PM981, 1TB Crucial MX500, Fractal Define R4
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 48GB DDR3 1600MHz, EVGA GTX 970 ACX 2.0, 500GB, 250GB & 120GB SSD, 10TB & 2x 4TB HDD, Fractal Define R5
PC 3: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Phone: Samsung Galaxy S23 256GB Watch: Samsung Galaxy Watch7 44mm LTE
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
Z77: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 32GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
For computers, weirdly enough its a low quality PSU by Aerocool, the KCAS 600w.
I bought it i believe in 2011, used for a year or so and then sold it on a complete system to a friend because he wanted to spend the least amount of money possible.
Anyway, it still runs today and i see it pretty often, it has at least 7 years of continuous use.
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
Doesn't really matter.
A PSU that old is just total garbage by todays standards, even if it was brand new and in mint condition.
But after all that time, who knows what failed or how close it is to failing??
This was in use just a week before I took the Pics:
And also keep in mind, just because a cap looks good doesn't mean its fine, like this one:
That's how a leaky Capacitor looks on an Atlas ESR Meter...
"Hell is full of good meanings, but Heaven is full of good works"
  • 4 weeks later...
I think I trust a PSU that has been running fine for 10 years before I'd trust a brand new one.
It's like buying a used car vs new. You buy new, and you could get a lemon. At least the used one is tested and true.
That being said, I wouldn't run one thats older than 6-8 years in a brand new system. But I'd go with an old PSU that was expensive at one time vs a new budget PSU like some of Corsair's flamethrowers. (VQ?)
Corsair HX1000w
It could power the system while killing it at the same time through excessive ripple. With a new PSU, you can easily get a replacement, and it's unlikely that it'll kill the rest of the PC. More likely it'll just not power on.
If you buy used, it could have a shoddy repair job that's on the verge of failing and lots of rust that you didn't see. Also, modern cars are safer, more fuel efficient and have up to date entertainment systems. Similarly, newer PSUs perform better.
If an older PSU is cheap, it's because it's outdated. Would you rather get a Ryzen 2600 for $160 or an FX-9590 (originally $920) for the same amount?
