Hi, I have a GTX 960 graphics card and a H370-A ASUS Motherboard, and am building in a NXZT H500 case. I've already used the pre-installed standoffs and screwed them in. I've also taken out a few of the case grills.
However, it seems my gpu is too large(it keeps hitting my mobo when I try to install it).
Is the a problem with how I installed the motherboard, or is it my motherboard vs gpu size that is the problem?
My PCPartPicker list:
For reference: This guy was able to install his GTX 1070 on a very similar mobo, H370-PLUS , with little problem.
My installation was pretty much the same, and I mounted my mobo on the same position standoffs.
https://linustechtips.com/topic/1049043-problem-fitting-gpu-in-motherboard/
What do you mean it keeps hitting the motherboard?
Do you mean the metal fingers that stick towards the motherboard? Those go between the motherboard and the case.
usually it's the I/O bracket of the card not slipping in properly. Wiggle more.
off topic, but who the [18+] puts an 8700k on a H370 board?
Desktop benching:
Are you sure you've taken out the right grills? Remember to take out the one next to the slot and the required amount BELOW that.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
Graphics cards I/O plate fins not sliding between the computer back I/O plate and the edge of the motherboard?
If so then it is the fins at the bottom of the Graphics I/O plate that are causing it not to set not the motherboard or case.
Probably due to being in a bent state.
Two fixes:
1. Bend the fin tabs back into alignment.
2. Cut the metal tabs off the end of the graphics card I/O plate -though if not confident with cutting metal seek someone who is qualified to do so.
           -I can tell you I had it before myself -I just get metal cutters and cut the fin tabs off level with the rest of the card then the card was able to fit in.
FTW: 6129m7Z2iHL._SL1500_.jpg
Make sure to still the screw in or the card will be highly unstable.
          Note: Some duct tape or electrical tape should be applied to the cut afterward may help with the sharpness -don't advise sanding that could be a worse can of worms if this route is chosen.
Current computers:
Primary Computer (In Progress):
SUBJECT TO CHANGE
CASE: ROSEWIL THOR V2 Black
CPU:
Motherboard:
GPU: SAPPHIRE VEGA 56 -TBU RTX 2070 SUPER
RAM: 48 GB CORSAIR VENGEANCE LPX
PSU: SEASONIC PRIME 1300 W GOLD
STORAGE: 4x SEAGATE EXOS 4TB | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
SOUND SYSTEM: Logitech Z506 Surround Sound via Vantec USB External 7.1 Channel Audio Adapter
MOUSE: 16000DPI GAMING MOUSE
KEYBOARD: -PENDING-
MONITOR: -PENDING- AOC AGON AG241QX 24" -PENDING-
COOLING:  CPU: Noctua NH-D15 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
LAST UPDATED 4/29/20
Secondary Computer:
CPU: AMD FX-8370 Black Edition
Motherboard: ASUS M5A97 R2.0
GPU: Zotac GeForce GTX 970 AMP! Omega Core Edition
RAM: 24GB Kingston HyperX Savage 1600MHz DDR3
PSU: Antec High Current Gamer HCG-900W
STORAGE: 5x Western Digital Black 2TB - WD2003FZEX | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
MOUSE: PUREX 2400 DPI Wired Laser Gaming Mouse
KEYBOARD: DBPOWER 104 Key -3 Backlit -I KNOW! Linus doesn't approve -I have glued it to the desk and it works well for my needs.
MONITOR: ASUS VS247H-P 24 Inch
COOLING: CPU: Noctua NH-D14 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
GRAPHICS: 2x NF12s fans on graphics card + 2x NF-F12s & 1x NA-A12x25 in Fan box | 1x Vantec SP-FC70-BL Spectrum System Fan Cards
Update:
So the proble all along was the my GP had to be in 1 slot down in the io shield, and it could fit in. D'oh! I'm typing this from my newly built pc, the first one I've built from almost entirely custom parts, instead of rebuilt.?
