Hi all
Just upgraded from ubuntu 16.04LTS to 18.04LTS. Setting up samba to act as a nas and the config file is different?
It seems that it uses different commmands and parameters?
Wanted to paste old config into new server as i had tuned it and was getting 125MB/sec.
Any ideas on how to tune the new style config file?
Thanks
Server 1:  CPU: i3 2100T  SSD: 840EVO MOBO: DQ67OW NIC: i340 -T4
Server 2:  CPU: Pentium D  MOBO: Dell Dimension 5150
Switch 1: Netgear GS108
Switch 2: Cisco 3500
https://linustechtips.com/topic/1047103-samba-help/
I've been using the same config since 14.something and I'm on 18.10 now. I haven't needed to change mine. Perhaps you're using some less-often used feature that has been deprecated?
https://linustechtips.com/topic/1047103-samba-help/#findComment-12416822
