Changing my case and my cooling to fit my new upgraded components in! I'm currently running this setup:
MSI Gaming Z87-G45 Motherboard
Intel i5 4670k @ 4.4GHz
16GB Avexir Core Series White DDR3 2400MHz
EVGA Nvidia 780Ti SC ACX
64GB Crucial C300 SSD (OS)
120GB Corsair Force LS SSD (Shadow play recording)
2 x 120GB Samsung 840 EVO SSD (RAID 0, Games)
I'm replacing my case and cooling (currently a NH-D14, with all noctua fans in a Fractal R3) with:
NZXT H440 (Black)
Corsair H100i
6 x Corsair Quiet Edition AF120 Fans
I'll post up some photos of the current case soon, and then I'll post as stuff arrives and I put it all together! (Case isn't actually out yet, it's on pre-order).
https://linustechtips.com/topic/104651-nzxt-h440-build/
Just one thing - H100i Isnt really better than NH-D14, maybe just a 1-3 degree difference...
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/104651-nzxt-h440-build/#findComment-1399495
NZXT H440 (Black)
Corsair H100i
No HDDs? Also keep the D14.
Quote me to get a reply!
https://linustechtips.com/topic/104651-nzxt-h440-build/#findComment-1399496
I only use my PC for gaming so I have no need for massive storage space. I use a MacBook Pro for work and have large external drives for that.
The performance of the D14 is amazing, however it obscures the RAM (which has LEDs in and looks cool) and also in my current case I can't put the side door on with the D14 fitted as the RAM is too tall for it to be installed correctly. Therefore the h100i is purely for looks!
https://linustechtips.com/topic/104651-nzxt-h440-build/#findComment-1405166
I am happy you are choosing black. I need to see this case with a build.
NZXT H440 l Inel Core i5-4670K l Z87-GD65 l MSI 780 Twin Frozr l Kraken x60 l Corsair RM 650 l Seagate Barracuda 2 Tb l Corsair Force GS 128 Gb l Teleios Sleeving l Acer H236HLbid l Corsair K70 Anodized Black l Roccat Kone Pure Color
https://linustechtips.com/topic/104651-nzxt-h440-build/#findComment-1406803
