help me please! fast
Go to solution Solved by Alan G,
It also could be the PSU that has gone bad.  On startup the PSU sends a power good signal and if it's not "good" the PC won't start.  I had a Seasonic PSU that had this problem a month after the warranty ran out and the PC would only start up about 5% of the time.  You would have to have a PSU tester to check this.
So i've got my new pc, built it myself for about 3 months ago, now it wont start, i have tried to jump start, i have tried to remove psu cables and the battery and then wait, and set them in again, i have tried to remove ram sticks and tried only 1 at a time on all different sloths with both sticks, im cluesless!  Since im going to an esport school its kinda important to have a working gaming desktop and im 17 and have my own apartment with a low paying part time job so i cant afford new parts, is there anything i have missed?
Specs:
Asus ROG Strix b360-f gaming
Palit geforce 1080 dual fan
intel core i7-8700
Seagate 1tb harddrive
920 evo ssd
2 corsair vengence 8x2 ram sticks
https://linustechtips.com/topic/1046080-help-me-please-fast/
Was it working before? As far as I know 200 series chipsets only support up to 7th gen processor. It is possible that you might've killed your CPU or the motherboard.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407147
the psu cable is plugged in, all the psu cables are, its set to 1, the motherboard and chassi gets power, since their led is lit up, the pc has worked fine for 3 months and i havent touched it since, (on the inside) i used it this morning with no trouble.
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407154
Make sure you quote people so they see your response.
Also, @PopsicleHustler is right, a B250 motherboard wouldn't work with an i7 8700, something is amiss.
By the way, when you say the chassis gets power, that doesn't make sense. The chassis is the case, do you mean RGB LEDs?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407159
b360-f gaming* and yes i mean the chassi's led and power button led
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407176
Ok, so we'll start with some basic troubleshooting. What happens when you try to boot with no graphics card?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407182
any exact circumstances it "died" under ?
at this point we know the PSU is good and the system is getting power but isn't posting. Looking up your MB there should be a feature called Q-LED for quick troubleshooting Q-LED.jpg
What do you see on the board ?
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407193
ok so there is a red light but there is no text around it
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407206
1 minute ago, saxenn said:
So is it the cpu thats not working? since i wrote it wrong before, its a Rog strix B360-F Gaming with a i7-8700
Usually something like this would pop up with a bad overclock but this is a non K build.
Check CPU power is plugged in all the way ?
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407224
Somethings up with the CPU, yeah. Hard to pinpoint without a POST code, do you have a POST speaker installed?
A girl who loves to love.
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407226
The cpu cable is plugged as long in as it gets. I have not overclocked the Pc and i used it this morning, turned it of as usuall, got home, it didnt start.
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407231
Do not have one of those no :(
yeah figured, I could go on a rant about how newer motherboards come with shit to get a post code off of them but that won't help you.
At this point try reseating the CPU, maybe some thermal paste or something got under there.
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407242
Did not make any difference :(
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407286
try unplugging and plugging in the 12 pin power cables and cpu power connector on both mother board and psu sides, to ensure they are well connected because the system must post even if the cpu has a problem
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407304
at this point you probably need either another CPU or another MB to try and determine if it's the MB or the CPU.
sigh, I don't wanna waist your time but try disconnecting everything non essential, Hard drives, SSD, Video card, CD-rom etc and see if you get any better results
https://linustechtips.com/topic/1046080-help-me-please-fast/#findComment-12407312
