How is the cable management? Are there any places where to improve on it?
Uploaded with ImageShack.us
My Rig-
  • CPU - Intel Core i7 3770
  • Motherboard - Asus P8Z77 V Pro
  • RAM - 2x4GB Corsair Vengeance @ 1600Mhz
  • GPU - Asus GTX 660 Ti DC2 @ 1100Mhz Boost
  • PSU - Corsair HX650
  • Case - Corsair 500R White Edition
  • CPU Cooler - Cooler Master Hyper 212 Evo
  • Monitor - Samsung S22B370H 21.5'' 1080p
  • HDD - Seagate 1TB @ 7200rpm
  • Optical Drive - LG DVD Writer
  • Keyboard Mouse - Logitech MK200
https://linustechtips.com/topic/10459-my-first-build/
Cable management is good man
CPU:Intel i7 2700k OC @4.9Ghz cooled by custom water loop with xpsc dual240 rads, xpsc block and 750 pump/res|Ram:G-Skill RipJaw X 32GB 1866Mhz|Case: Corsair 750D|Motherboard:Asus Sabertooth Z77| Hard drive: 240GB Kingston SSD, Seagate 2TB, 1TB Hitachi |GPU: EVGA GTX 770 SC cooled by custom water loop with xpsc gtx 770 block|PSU: Corsair HX750|Monitor: LG 27 inch IPS LED Cinema| Sound Card: Creative Fatal1ty X-FI professional| Build log:
https://linustechtips.com/main/topic/64792-just-finished-off-first-watercooled-rig/
https://linustechtips.com/topic/10459-my-first-build/#findComment-112441
Thnaks!
My Rig-
https://linustechtips.com/topic/10459-my-first-build/#findComment-112573
That is a really nice build, I can't believe that you asked for help with the cable management because it looks as though it is the best you can get without custom sleeving :D
Specs?
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/10459-my-first-build/#findComment-112602
That is a really nice build' date=' I can't believe that you asked for help with the cable management because it looks as though it is the best you can get without custom sleeving :D Specs? [/quote']
CPU- Intel Core i7 3770
Mobo- Asus P8Z77 V Pro
GPU- Asus GTX 660 Ti Direct CU2
RAM- 2x4GB Corsair Vengeance 1600Mhz
PSU- Corsair HX650
CPU Cooler- Cooler Master Hyper 212 EVO
HDD- Seagate 1TB
Optical Drive - Some Cheap LG one :P
My Rig-
https://linustechtips.com/topic/10459-my-first-build/#findComment-112908
Cable management is decent, I would get 2 sleeved extension cables for the 24pin and the 8pin.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/10459-my-first-build/#findComment-113564
Cable management is decent' date=' I would get 2 sleeved extension cables for the 24pin and the 8pin. [/quote']
Where can i find those?
My Rig-
https://linustechtips.com/topic/10459-my-first-build/#findComment-113628
https://linustechtips.com/topic/10459-my-first-build/#findComment-113636
Cable management is decent' date=' I would get 2 sleeved extension cables for the 24pin and the 8pin. [/quote'] Where can i find those?
http://www.bitfenix.com/global/en/products/premium-modding/alchemy-cables/
http://www.nzxt.com/new/product.php?series_name=Premium+Cables&series=13
https://linustechtips.com/topic/10459-my-first-build/#findComment-113664
Would probably be a good idea to get just the 24 pin and the 8 pin braided cables. The other cables are barely seen at all to be honest.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/10459-my-first-build/#findComment-113781
Awesome build man!
Computer: CPU: Intel i7 3770k 4.2 GHz, Processor Cooling: Corsair 100i,  Video Card: ASUS Geforce GTX 660ti, Motherboard: ASUS P8Z77 V PRO, Power Supply: corsiar AX750, Hard Drive: Toshiba 2TB, Case Fans: Bitfenix Specter x 2, Case: Phantom
https://linustechtips.com/topic/10459-my-first-build/#findComment-114121
Yea Awesome build if you are feeling OCD then you can do what others are suggesting get a 24 pin extention cable that is sleeved you can find them on newegg or ncix or just about anywhere as well as your 8 pin atx power connection. Also, something in the future go maybe consider a ssd man :) all in all I love the build and I think that motherboard really meshes awesomely with your case.
https://linustechtips.com/topic/10459-my-first-build/#findComment-114147
I live in india so newegg and NCIX wont work for me :(
I cannot buy a whole set of sleeved cables because my PSU is semi-modular.
My Rig-
https://linustechtips.com/topic/10459-my-first-build/#findComment-121302
