ok i upgrading my old system a little and hard line water cooling it to give to a friend.
I have a res and a D5 pump already bu my problem is that I'm using a smaller case this time round i need to save space so i need to find a combo that is just an upgrade to add the pump too the bottom of the res and i cant seem to find any.
If anyone has any suggestions or links i would be very great full.
thanks
https://linustechtips.com/topic/1045699-pump-res-combo/
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1045699-pump-res-combo/#findComment-12403612
7 hours ago, mrcalcutter said:
EK series 250
pump is a standard D5 also from EK
case I'm using is a Inwin 305
EK has shorter res combo unit so you can re-use the pump.
https://www.ekwb.com/shop/ek-xres-100-revo-d5-acetal
https://linustechtips.com/topic/1045699-pump-res-combo/#findComment-12405166
