This depends on what you want from your mechanical keyboard.
This seems to be an extremely detailed guide:
https://www.daskeyboard.com/blog/mechanical-keyboard-guide/
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1045362-mechanical-switches/#findComment-12400567
3 minutes ago, JackBoggio said:
I am looking at Cherry speed silvers, are they clicky and good?
They're pretty decent actually. To give you some context, I'm faster on Cherry MX Speeds/Silvers than Cherry MX Blues. Honestly, you should go to a local store that sells mechanical keyboards and try out different key switches, or you could just buy a mechanical switch tester. No one can tell you what switch is perfect for you, you'll have to try out different switches for yourself.
Welcome to the LTT forums!
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1045362-mechanical-switches/#findComment-12400571
2 minutes ago, JackBoggio said:
does anyone know if they are clicky like blues or more like reds and browns?
Cherry MX Speeds/Silvers are linear, so they'll feel more like Cherry MX Reds than Blues or Browns.
https://linustechtips.com/topic/1045362-mechanical-switches/#findComment-12400593
Thanks everyone for the replies, I am pretty sold on the Silvers, but i am wondering about one thing- does anyone know if they are clicky like blues or more like reds and browns?
They are REALLY light & fast, even lighter than red.
https://linustechtips.com/topic/1045362-mechanical-switches/#findComment-12400595
Mx silvers and most mx switches in general are scratchy and just very mediocre. Mx Speed Silvers are a light-medium stiffness linear switch and is not clicky. Some other recommendations for good switches are:
Clicky: Box Jades & Other box click bar designs, Matias Click, Zealiostotles
Tactile: Mx ergo clears, Zealios/Zilents, Box Jades, Holy Pandas, Hako True/Clear Royals
Linear: Tealios, Tangerine C3s,  Modern Gateron Linears, Linear Box switches, Kailh Creams
Before buying a keyboard try and do some research, on places like r/mechnicalkeyboards, deskthority, geekhack etc.
https://linustechtips.com/topic/1045362-mechanical-switches/#findComment-12400705
10 minutes ago, b emoji said:
Mx Speed Silvers actuate the same force as mx reds
You are correct, the force required to move these two switches is the same
But me personally don't bottom out when typing, so for me silver is faster and lighter.
I forgot to clarify that, mb
https://linustechtips.com/topic/1045362-mechanical-switches/#findComment-12400712
