Nomenclature help needed
Go to solution Solved by Radium_Angel,
32 minutes ago, docomeister said:
Thanks, take care!
That's a hot shoe mount
Hi guys, I need help finding out what this mounting standard is called, for googling purposes. Trying to find a tripod mount adapter for either this typical sliding mount for camera attachments or an adapter to the larger screw size that is on the mic in the attached photo (they just couldn't put a standard tripod mounting hole size on it, it seems). Some keywords would be great help, so I can search the adapter on my own, but let me know if you also happen to know exactly what I'm looking for in order to get this mic mounted to my tripod.
Thanks, take care!
MOBO: MSI Krait Gaming X370 | CPU: AMD Ryzen 5 1500X [4GHz @1.43V] | RAM: Kingston HyperX Fury 2x8GB 2133MHz [2933MHz CAS 16]
GPU: ASUS GTX1060 6GB DUAL Series | SSD: HyperX Fury 120GB | HDD: WD Blue 1TB
CASE: Thermaltake Suppressor F51 | PSU: Corsair VS550 | COOLING: Corsair H60 [70°C Max @1400rpm] | DISPLAY: LG 29" Ultra Wide, BenQ 1080p Projector
MOUSE: Trust GXT31 MOUSE MAT: HyperX Fury | KEYBOARD: Logitech G510s | UNDERWEAR: HyperX
SOUND: Creative Sound Blaster Omni 5.1 | HEADSET: HyperX Core Cloud | SPEAKERS: Behringer MS16, SONY HT-RT3
CPU-Z Validator: DUCKPC
https://linustechtips.com/topic/1044998-nomenclature-help-needed/
Hi !
Is this not a flash mount ?
Just another engineer posting useful hardware videos directly to the interconnected network (AKA the internet)
Tech enthusiast. Check my channel out here https://www.youtube.com/channel/UC6FU1nfeGBBnw_bvHgWCqTQ
Yeh now I remember that's the one! Thanks, now I can find loads of adapters!
