I'm pretty sure you haven't connected your VGA cable to your RTX 2060 - seeing that the RTX 2060 doesn't have VGA ports (unless you're using an aftermarket board design that I've never heard of?)
Maybe post a picture showing your current setup so we can help you better?
Also what @Brooksie359 said
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/1043920-guys-i-need-help/#findComment-12388033
